I have a question about using the studs.
I bought two rims that are ET 38 and these match exactly to my pair that will be going in front.
Here's the catch, the hub design is simply shorter than the wheels that are going up front...ET 25.
It seems like the length is going to be exactly the same if not maybe a bit longer.
What should I do? Measure the distance first or go with 60mm or 80mm stud kit.
Do you think the 80mm kit will be overkill for the front's?
Or should I mix and match, 60mm's for the front and 80mm's for the rear.
