Author Topic: Change the timing chain tensioner the easy way  (Read 52807 times)
danhx
« Reply #30 on: July 19, 2008, 04:52:16 PM »
nevermind, problem solved. Exchanged the tensioner and installed per the directions in this post, and Olie (that's my car ...) hasn't sounded this happy since I bought him a few weeks ago.
quinn11m20
« Reply #31 on: July 21, 2008, 08:50:14 PM »
Yup I think its because i use a thick oil. It took longer than usual to quiet down. I use 20w50. I have 237k miles on the car and I would like to go to a thinner oil like 10w30, why I don't know. Any suggestions? I have been running 20w50 for years. I have owned the car since 97.
KyleTaylor
« Reply #32 on: September 09, 2008, 03:44:26 PM »
guess I have to do lifters as mine is still just as noisey.
rallyegolf
Timing tentioner
« Reply #33 on: November 26, 2008, 04:31:54 PM »
What are you guys paying for the tentioner and where are you getting them? I found the Febi Brand for $50  Is that a good deal?
vonkamp
« Reply #34 on: November 30, 2008, 08:03:43 AM »
Quote from: rallyegolf;61763
You might save a few bucks at Pelican parts...
92 318i Cabrio
iamcreepingdeath
« Reply #35 on: April 06, 2009, 10:24:19 PM »
awesome write-up.  I am about to do my tensioner, just got mine from BavAuto.  Any reason why two tensioner came in the box?  there aren't like two parts or anything is there?  just one cylinder looking thing?
xwill112x
« Reply #36 on: April 07, 2009, 12:17:42 AM »
yeh, it should be in one piece.
Ich liebe meinen E30
iamcreepingdeath
« Reply #37 on: April 07, 2009, 07:12:25 PM »
weird i guess i accidentally got two.  anyone wanna buy one?
iamcreepingdeath
« Reply #38 on: April 10, 2009, 02:35:17 PM »
replaced my tensioner last night, and sold my extra one on R3V, and my M42 now starts cold perfectly and quietly, no chain noise, i am very happy!!  and i did it the easy way, thanks to the OP!!
romeomike
A little extra drama with a happy ending
« Reply #39 on: April 20, 2009, 02:58:29 AM »
Here's how it went for me:
Got the 19mm screw plug off easily with a breaker bar. :)
Couldn't push the extended chain tensioner in with my hands. :confused:
Drop the tensioner and watch it fall into two pieces and a displaced lower split ring. :eek:
The metal gasket ring (07119963355) around the screw plug falls and disappears into an alternate universe. :(
I offer passionate entreaties to God about this series of events. :mad:
I look up on realoem.com that an M10 uses the same gasket ring.:cool:
Pick up the gasket ring at the salvage yard and a six-inch C clamp from a hardware store.;)
Successfully compress the tensioner using the C clamp with a little nudge on the lower split ring with a small screwdriver and am able to lock it in so it doesn't fly apart. :)
Move the windshield washer tank out of the way and can get the chain tensioner, gasket ring, and screw cap to thread by hand. :):)
After cinching up the screw cap with a 3/8 inch ratchet, only takes 3 seconds of noisy idling before the tensioner fills with oil. :D
The engine is a bit quieter, and I am grateful.
« Last Edit: September 03, 2009, 11:15:18 AM by romeomike »
johnwoo
« Reply #40 on: April 20, 2009, 05:09:30 AM »
anyone have a part number for the m44 tensioner?
romeomike
Same for both M42 and M44
« Reply #41 on: April 20, 2009, 12:49:29 PM »
Quote from: johnwoo;70420
11 31 1 743 187
It's part 21 in the graphic accompanying this link
http://www.realoem.com/bmw/showparts.do?model=CD73&mospid=47493&btnr=11_1564&hg=11&fg=25&hl=22
BlackBMWs
« Reply #42 on: May 28, 2009, 07:11:42 PM »
Used this same method on my M62TU and it worked just fine.  Just have to press in and turn at the same time.
I have a new tensioner ready for the 318ic fixer I am picking up this weekend.  I have a 400 or so mile ride home, so I will change the oil on the spot, drop the new tensioner in and have a pair of rad hoses on hand JIC something comes up.    :cool:
BTW, this is a really nice site for info.  You all have done a great job...
BMWCCA# 160411
laernu
« Reply #43 on: June 28, 2009, 07:13:43 PM »
do i have to keep my chain on time when i do this or can i just do this without having to touch anything but the writing mentioned in the guide?
**Nevermind got it to work perfect lol just finished it now runs great for now hopefully it will do the same when i actually drive it and do my normal pushing :)**
« Last Edit: June 28, 2009, 07:55:08 PM by laernu »
Brian318is
« Reply #44 on: June 03, 2010, 08:42:44 PM »
Did this today with great success.. while showing my wife how the tensioner works, it came apart and sprung all over my driveway. Fortunately, it was the OLD tensioner!
Installed and works great. Thanks for the write-up!
