Author Topic: Change the timing chain tensioner the easy way  (Read 52988 times)
« on: June 06, 2007, 02:22:28 PM »
Reading through the various methods and debates out there about changing the timing chain tensioner, most call for installing the tensioner compressed as it comes out of the box, then once installed rev the engine to 3500 rpm and cross your fingers the loose chain will slap the chain rail against the tensioner to release it before the chain jumps a tooth or 3. The whole reasoning behind this method is that you won't be able to install the chain tensioner once its extended. I don't know how this idea got started but I think its WRONG. Here's my simplified method.
1. Remove the old tensioner via the 19mm bolt on the passenger side of the engine. Once out it will look like this. Old extended tensioner is on the right, M44 style compressed tensioner on the left.
2. De compress the new tensioner by pressing the ends down against the table with your hand and twist about 1/4 turn. It will pop out and look like this.
As you can see fully extended the new tensioner is slightly longer than the old tensioner. This is due to wear on the old tensioner spring and part of the reason why it needs to be replaced.
3. Install the new tensioner the same way the old one came out. When you reach the point where you need to thread the cap back in, apply pressure to the tensioner. My guess is that it takes about 20 lb of pressure to compress the spring with one hand on the head of the cap. Its not that hard to compress. The cap can then be tightened by hand when the threads catch.
4. Tighten the cap with a 19mm wrench to torque spec. Since I don't have a torque wrench just used my own estimate. Remember that the threads are in aluminum so don't over do it. Think of of it as an oil drain plug. I removed the valve cover to paint it as well as inspect the timing chain gears but its not necessary. In the red circle you can see the head of the new tensioner fully extended.
5. Once everything is buttoned up, start the engine and let it idle. You will get a very loud chain noise for a split second until oil pressure reaches the tensioner, then it will get quiet all of a sudden. You don't have to rev the engine. Just let it idle for a minute or so. It should give you time to check for oil leaks from the tensioner bolt.
Remember that this isn't the only way to replace the tensioner. The 2 articles below outline a different method that has been proven to work effectively many times over. I'm just offering another alternative that worked for me.
http://www.bmwe30.net/cgi-bin/datacgi/database.cgi?file=articles&report=view&ID=00072&Section=08
http://www.esatclear.ie/~bpurcell/318isfaults.html#timingchaintensioner
« Last Edit: June 07, 2007, 01:02:18 PM by tjts1 »
RED IS 91
« Reply #1 on: June 06, 2007, 03:32:34 PM »
great info and a great how-to .
Unfortunately for me I just replaced my tensioner .I did the cross my fingers and rev to 3500 method.
Everthing worked out but still a tense moment.
kowalski
  • El\' Duder
« Reply #2 on: June 06, 2007, 03:36:01 PM »
i did it by installing it decompressed with no problems as well. Seemed like the sensible thing to do to me.
Sale:
Fore Sale Thread
Vladi
    • http://www.bmwzone.ro/forum
« Reply #3 on: June 06, 2007, 05:23:49 PM »
« Reply #4 on: June 06, 2007, 07:35:35 PM »
Quote from: Vladi;27234
Does anyone know when should we change parts 17, 8 and 10?
http://www.realoem.com/bmw/showparts.do?model=BE51&mospid=47425&btnr=11_1370&hg=11&fg=25
A lot of info on the subject here.
http://www.esatclear.ie/~bpurcell/318ismaintenance.html#timingchain
Good luck.
By the way, I was born in Bucuresti. I speak some Romanian but writing is a bit tougher. Moved to the US in 1990.
« Last Edit: June 06, 2007, 07:43:02 PM by tjts1 »
sheepdog
  • Site Admin
« Reply #5 on: June 07, 2007, 12:08:50 AM »
If the tensioner is kept in check, the guides will go for a VERY long time. Much longer than 100k, but only if the tensioner is not allowed to wear out.
Cheap insurance is replacing the tensioner every 40k.
To my knowledge, none of this has an official service interval.
« Reply #6 on: June 07, 2007, 02:08:54 AM »
Quote from: tjts1;27239
Good luck.
Holy crap.... another Romo in the house. What are the odds of this. LOL
Vladi
« Reply #7 on: July 11, 2007, 05:55:31 PM »
Good luck.
Glad to know it! :D
Quote from: Eurospec;27273
Dude, there's something fishy going' on here. :D
Asserti
« Reply #8 on: January 15, 2008, 07:41:48 AM »
So this is the best/safest/ most recommended way to replace the chain tensioner?
I'm going to do mine in a few weeks.
[/URL]
sheepdog
  • Site Admin
« Reply #9 on: January 15, 2008, 02:38:05 PM »
Quote from: Asserti;41245
Ignore pulling the cover.
Instead, pop the new tensioner prior to install.
It makes it only a little more difficult (easy job still) and ensures no problems.
Takes 5 minutes to change it this way.
Asserti
« Reply #10 on: January 16, 2008, 03:56:37 PM »
Thank you very much!
I still think this is one of the best boards I've ever registred. I'm sorry that I'm not more active here, have some other boards that take allready a lot of my time.
Keep up the good work though!
[/URL]
Nomadic
« Reply #11 on: February 23, 2008, 06:54:17 PM »
I did it this easy way and it worked like a charm. (decompressing the tensioner first and applying pressure to 19mm cap to thread to install )  There still was some brief slapping while the tensioner was filling up with oil and coming up to pressure, but worked well.
Thanks for the post!
e30 4cyl
« Reply #12 on: February 23, 2008, 11:05:19 PM »
Thanks for the writeup, I will need to do this eventually.
bmwpower
« Reply #13 on: February 24, 2008, 02:37:50 AM »
+1
Did this when I fired up my engine for the first time the other day.  Does make a lot of noise for maybe 5-6 seconds and then you're good to go.
keflaman
  • -Receive: 35
« Reply #14 on: February 24, 2008, 03:19:29 PM »
Worked like a charm. My chain noise disappeared almost instantly and I can't believe how much smoother and quieter the motor is.
