Author Topic: Can anyone identify this connector?  (Read 3409 times)
sheepdog
  • Site Admin
« on: June 05, 2007, 12:28:05 AM »
While replacing my fan resistor, I came across this connector.
It is disconnected obviously, and it is how I found it.
It is the only connector in the harness in that area.
My panel next to the rear view is disconnected, due to a previous owner, and when plugged in does display errors, but it has been a year since I even hooked  it up for a second, so I am not sure which lights are lit. Check engine light works, as does oil, and such. Brake pad indicators do not work however.
Just hoping someone knows off the top of their head.
Not really a big deal, the car runs fine, I am just trying to save the hassle of pulling the upper panel and possibly connecting something I should not connect (causing a short?).
Is anyone else's connected?
It is a pretty thin wire so it is not carrying much current.
« Last Edit: June 05, 2007, 12:30:51 AM by sheepdog »
« Reply #1 on: June 05, 2007, 02:48:23 PM »
Are you talking about the full check control panel or the warning lights on the IP?
sheepdog
  • Site Admin
« Reply #2 on: June 05, 2007, 10:43:00 PM »
Quote from: gearheadE30;27138
Eh?
The panel right next to the rear view is disconnected.
I am just curious about the connector pictured though.
« Reply #3 on: June 05, 2007, 11:57:38 PM »
I believe it is not connected to anything on mine either.  I think it is for the LLCO output on the AFM that is used on non-O2 sensored / non-catalyst cars.
kowalski
  • El\' Duder
« Reply #4 on: June 06, 2007, 06:44:14 AM »
mine wasn't connected either.
Sale:
Fore Sale Thread
sheepdog
  • Site Admin
« Reply #5 on: June 06, 2007, 11:59:55 PM »
Thanks.
