Author Topic: Today, 15:07 Hairline Crack in Head (w/ large pictures!)  (Read 3989 times)
phredphish
« on: May 20, 2007, 03:17:56 PM »
What I want to know...
Is there some tolerance for cracks in a head? My old 735i/M30 manual had several diagrams outlining allowable sizes of cracks, but I also can't imagine it had an aluminum head on it...
There isn't any noticable corrosion around or in the crack...so that leads me to believe is is a relative non-issue. I'm just trying to cover all of my bases before I put this back together.
I can get some large pictures/different angles if anyone is interested. I cropped/sized these down for people with smaller screens/connections.
Here are the pictures:
Thanks.
Shocker
« Reply #1 on: May 20, 2007, 04:33:36 PM »
A crack in a head is not good no matter it's size.
ZeroG
« Reply #2 on: May 20, 2007, 04:35:08 PM »
It needs to be repaired by a machinist.  Any crack could cause the HG to leak and result if you doing all this work all over again.
kowalski
  • El\' Duder
« Reply #3 on: May 20, 2007, 05:36:58 PM »
i'd recomend finding yourself a used head, and getting it checked before installing it.
Sale:
Fore Sale Thread
scottiesharpe
    • http://bmwturboperformance.com
« Reply #4 on: May 21, 2007, 12:53:38 AM »
The head can be fixed by a machinst. They will bore out the crack and TIG weld it, then resurface. It may re-crack.
Scottie Sharpe
San Jose CA
www.bmwturboperformance.com
67 1600
68 2002 Dual Mikunis
73 Hardy & Beck tii
88 M5, Dinan Stage 4, M88, MAF
91 318iC, MAF
Do you BMW Wiki Wiki ?
« Reply #5 on: May 21, 2007, 04:44:30 PM »
My vote is get a new head. Also, get those valves cleaned off and the head steam cleaned before putting it back on.
Vladi
    • http://www.bmwzone.ro/forum
« Reply #6 on: May 21, 2007, 05:34:57 PM »
I've read before on the forum about head cracks. My 2 cent question is, why do they crack?? :(
Cristian G in Oz
« Reply #7 on: May 21, 2007, 09:23:18 PM »
Quote from: phredphish;26167
Thanks.
The M30 was an alloy head and the early ones had a propensity to crack in the 5th and 6th cylinders.
You could get it welded and the head shaved but there is no telling how long it will last.  Once a crack has started it is all downhill.:(
As stated above, if you can afford it get another head, it's not worth stuffing around with old problems.  Absolute minimum is to get the head welded and crack tested.
Good luck
Cristian
1990 318is
rsafier
« Reply #8 on: May 21, 2007, 10:35:19 PM »
Quote from: Vladi;26255
Uneven heating of the head usually due to overheating. But doesn't have to be sometimes just age and heat cycling can do it if there was a weak spot in the casting to begin with.
Turbo \'89 325i - The Solo Car
\'91 318is - The new DD
http://www.2slowracing.com">2SlowRcing.com
ecpreston
« Reply #9 on: May 22, 2007, 08:13:21 AM »
My vote is also for that crack being a problem. Pressurized, hot gas can pretty much get through any small crack. And then it's in your cooling system (I assume that's a water passage, yes?). Did you have any coolant temp issues or ever do a coolant pressure test before you disassembled?
Channing Preston
Madison Motorsports
phredphish
« Reply #10 on: May 22, 2007, 10:08:48 PM »
There weren't any discernable overheat issues, but that is assuming the temp gauge is and has been working properly.
I'm going to buy a new engine this week -- 66,000 miles on a 1993 m42 for not too much over what I've been quoted for a head rebuild, not bad!
Now, I've heard that a digital manual has been posted to this forum...is that so? I've lost my bently and will probably need some manual-based assistance pulling the old block and putting it all back together.
Any pointers from you experienced guys out there?
« Reply #11 on: May 23, 2007, 10:05:46 AM »
Digital  repair manual link. It's in the "M42 Reference" section of the User Control Panel:
http://www.m42club.com/forums/showthread.php?t=964
Also search for E36 M42 swaps. Several have been done using different approaches.
