Author Topic: Trim moulding removal?  (Read 3858 times)
FL318is
« on: May 20, 2007, 08:57:31 AM »
I need to remove this moulding.  Has anyone done this or know how to?  It looks like the small front piece is hard to get to.
Any help would be appreciated.
« Reply #1 on: May 20, 2007, 09:36:55 AM »
Stick a butterknife under it and pry.
:D
Actually, you can just get a good grip at the leading edge and pull.
« Reply #2 on: May 20, 2007, 10:09:35 AM »
It will pop out at the front and then you slide it to an open spot on the inside of the molding and it will come off leaving the clip on the fender. The molding clips can be purchased from BavAuto. They are hard to get off  - you have to push the pin out from the inside and some are hard to get to.
FL318is
« Reply #3 on: May 20, 2007, 09:44:17 PM »
THX.  I will keep you posted.
oldtimer
« Reply #4 on: May 20, 2007, 09:46:28 PM »
If this are the molding that runs the full length of the car.  The one on the door has two 10mm nut on each end take those out they should pop out.
FL318is
« Reply #5 on: May 20, 2007, 09:48:17 PM »
Thats good to hear.   What about the one between the door and the wheel?
