Author Topic: Setting TDC..  (Read 2770 times)
ZeroG
Setting TDC..
« on: May 19, 2007, 08:05:02 PM »
I am in the middle of replacing myu headgasket, I have the timing covers and chain removed as well as the cam sprockets.
I currently have the head tq'd to the block and the head is a TDC with both Cam lobes for cyl. #1 pointing in.
My problem is setting the block at TDC, I pulled the spark plugs, and placed a extention in cyl #1 so that I can watch the piston go up and down.  No matter what I do when the cyl is at the top I cannot get the TDC pin in.  I know that this totally has to be perfect or the cam timing will be off when I put it back together.
Does anyone have any ideas of how this problem can be solved.  No matter how many rotation of the crank, I cannot get the TDC pin in to put the timing chain back on the sprocket.
ZeroG
Setting TDC..
« Reply #1 on: May 20, 2007, 12:03:24 AM »
Quote from: ZeroG;26123
I think I figured it out..  I''ll keep my fingers crossed and report back.
ABuseO
Setting TDC..
« Reply #2 on: May 20, 2007, 10:05:02 PM »
Im getting ready to hit this process myself, please do reply back. Got the head ready to put on, my old one was cracked have to put a new one on, let me know how it goes. good luck!
ABuseO
Setting TDC..
« Reply #3 on: May 22, 2007, 12:04:22 AM »
Got my head on straight, taking it slow, hope it runs.
ZeroG
Setting TDC..
« Reply #4 on: May 23, 2007, 02:07:48 AM »
Quote from: ABuseO;26288
Nice good to hear.  I ended up just sticking an extention in cyl 1 and then rotating the crank until it was at the top not moving or or down.  I also made sure that the waldorff key was facing straight up, and both cam lobes for cyl pointed in.
