hello,
a quick update:
i bought a '93 e36 head last week. when installing the head this is what i found:
- head is identical in terms of water passages etc.
- valve stem diams. are the same (~7mm) up to 7/'94. after that they change to ~6mm
i used my own cams,lifters and bearings because they looked near perfect.
after i rebuild the engine it ran really bad, shaking violently with plumes of grey smoke. i noticed the air gap between the camshaft position sensor and the stub on the pulley was rather large. i got rid of the o-ring and used liquid sealant instead. this reduced the air gap, and it seems to be running fine now!!
what does this sensor regulate? ignition timing?
