Author Topic: Engine hesitates under high load after cleaning ISV and AFM  (Read 3061 times)
achtungE30
I used carb and choke cleaner attempting to clean the ISV behind the upper intake manfiold plenum and the AFM while removing the factory airbox and installing a hot air intake (temporary).
Now driving the car around and testing it (at night), didnt get a look during the day, at some point in accelerating the car hesitated and a light quickly flashed and went out, located next to brake lining light. When I pulled back into my driveway, I tried revving the engine and each time i seemed to hesitate right after i pressed the gas but revved as it should have, kinda like a stutter or shake.
What could this be?
*EDIT* Some more info..
I did a tune-up last year, new fuel filter, plug wires, plugs, oil and filter, didn't touch the o2 sensor yet.
When I did all my vacuum lines, i had the intake manifold out and lower manifold as well, and cleaned the injector jozzles by hand as best I could while still inside the plenum.
« Last Edit: May 14, 2007, 01:48:52 PM by achtungE30 »
Alpine003
« Reply #1 on: May 14, 2007, 04:04:10 PM »
Did you make sure you don't have any vacuum hoses or sensor wires loose or detached?
I often see people that have problems after installing something or doing some maintenance after overlooking some part they forgot to put back.
achtungE30
« Reply #2 on: May 14, 2007, 08:51:07 PM »
Pretty sure I had everything back in place. I'm worried the carb cleaner may have damaged a sensor in the AFM. I'll give it another look and see whats up :)
achtungE30
« Reply #3 on: May 16, 2007, 10:54:05 AM »
Update:
No I didn't overlook anything...all hoses seem to be secure...but I do hear a vacuum leak someplace!!
Last year I replaced all the vacuum lines. Does the hoses that connect on the ISV need to be clamped at all? Everything else that previous had a clamp is clamped.
I will also go over my intake manifold and valve cover bolts just to make sure they are torqued to specs.
Anything else?
kowalski
  • El\' Duder
« Reply #4 on: May 16, 2007, 12:11:12 PM »
i was under the impression carb cleaner was not sensor safe.
Sale:
Fore Sale Thread
achtungE30
« Reply #5 on: May 17, 2007, 07:39:46 AM »
So you theorize my AFM is shot now?
b318isp
« Reply #6 on: May 17, 2007, 08:02:54 AM »
The AFM track is inside the black casing and it is unlikely that any cleaner would have got to it.
kowalski
  • El\' Duder
« Reply #7 on: May 17, 2007, 10:03:27 AM »
there is a sensor in the AFM is there not? As well as the ICV could have also ran into some troubles with the cleaner. I would try swaping them out with a friends, and see if the problem goes away.
Sale:
Fore Sale Thread
Alpine003
« Reply #8 on: May 17, 2007, 11:27:08 AM »
Quote from: achtungE30;25914
Highly doubtful unless you have some cracks or holes in your AFM unit that would let cleaner get to some sensitive components. I've cleaned mine without any effect. I would try as others suggested and try swapping components.
