M42 Stroker Kit?
Author Topic: M42 Stroker Kit?  (Read 33441 times)
Bl3wByYou318T
M42 Stroker Kit?
« on: May 13, 2007, 03:03:18 AM »
As the topic says.Well i been lookin around alot as of lately there really isn't a kit out on the market.ALTHOUGH there is a few stroker kits for the older 4 cylinder bimmer motors.Id think some of the parts if not all would work since im pretty sure these motors share the same internals maybe bigger/smaller.But it would work id think.
Heres the kit i found pretty damn cheap also.
http://www.vacmotorsports.com/cgi-bin/view_item.pl?item_id=282
Im guessin since these 2 motors share the same block that with a little maching they'd match up.Also resleve the cylinders and port them lightly to get some more power out of her.
Im sure theres a way to pice together a m42 stroker for $2500 for the parts And pushin about 250-280hp without boost.And with a turbo kit probbly 400-600 hp depending on boost and turbo.
I been doing my research as you can tell.
Im just look for some professional opionions on putting togther a stroker m42 kit.
Also i can do about 95% of this work myself so thats really not a problem but if its somthing im afarid to touch then ill take it to a shop heh.
DutchM42
M42 Stroker Kit?
« Reply #1 on: May 13, 2007, 04:52:02 AM »
Well, the 318is STW did 295 hp. But that engine is worth like 80000 dollars. For 2500 dollar you will end up with nothing special. Camshafts/ ECU/ intake/ pistons/ rods/ headwork/ it will be much much more expensive.
kowalski
  • El\' Duder
M42 Stroker Kit?
« Reply #2 on: May 13, 2007, 08:57:10 AM »
the s14 crank wont fit in the m42.
Sale:
Fore Sale Thread
Bl3wByYou318T
M42 Stroker Kit?
« Reply #3 on: May 13, 2007, 02:23:49 PM »
Well that sucks.Guess ill have to go with the m42 turbo kit which perpares the engine for boost from what i can tell.
http://www.vacmotorsports.com/cgi-bin/view_item.pl?item_id=646
Pretty basic for $2200 I just wonder how much boost i can push thru a fresh engine using this kit before hand.
Probbly 8lbs to 15lbs and make 200-250 hell maybe 300.No one really knows how much boost you can run thru these engine till they go heh.
I guess our engines are scrap compared to the older 4 bangers by bmw.
Funny how they made such high perf 4 cylinders back then and till the 318i rolled out all that stopped.
But maybe theres a company out there that actually mods these motors.Theres gotta be one id like to think that at least.
*Edit*
Also i bet theres someone on these very forums that has stroked one of these engines.If not on this forum then its probbly on another.Someone must have done this before :).
« Last Edit: May 13, 2007, 02:27:16 PM by Bl3wByYou318T »
Jtuner
M42 Stroker Kit?
« Reply #4 on: May 13, 2007, 02:50:13 PM »
I was under the assumption that the bottom end of the m42 had all forged pistons/rods/crank...? sooo, what's the difference between that kit, and a stock rebuild kit? I suppose other than the head gasket, and the super strong arp head studs??
M42 Stroker Kit?
« Reply #5 on: May 13, 2007, 03:29:24 PM »
Search is your friend!
There are several strokers here on the boards, along with a few people running boost!
Search!!
http://m42club.com/forums/showthread.php?t=1385
http://m42club.com/forums/showthread.php?t=1768
http://m42club.com/forums/showthread.php?t=538
http://m42club.com/forums/showthread.php?t=254
Quote from: Bl3wByYou318T;25635
*Edit*
kowalski
  • El\' Duder
M42 Stroker Kit?
« Reply #6 on: May 13, 2007, 05:21:37 PM »
i've got a stroker kit sitting in my room for a 2 liter. I just have to find a core to put it into...
unless of course you want to buy it.
Sale:
Fore Sale Thread
2002maniac
M42 Stroker Kit?
« Reply #7 on: May 13, 2007, 08:05:04 PM »
Quote from: Jtuner;25637
Only the crank is forged.
Tor Arne Kaasen
M42 Stroker Kit?
« Reply #8 on: May 13, 2007, 09:15:24 PM »
http://www.koed.dk sells stroker kit fot the E30.
se E30, nye deler(new parts),tuning,motortuning,side 4. m42volumeforøkelse kit(stroker kit)
BMW E82 120d Coupe and BMW Z3 1,9 m44
Bl3wByYou318T
M42 Stroker Kit?
« Reply #9 on: May 14, 2007, 03:36:15 AM »
Kow how much you asking?
Tor arne kaasen.Awsome site there man but i can't understand the langauge : (.Sucks they can't transfer everything into english only bits.
Thanks for the 411 guys :).
kowalski
  • El\' Duder
M42 Stroker Kit?
« Reply #10 on: May 14, 2007, 04:48:04 AM »
i looked under what you said, and nothing shows up for a stroker kit, i don't get any engine parts listed. I checked under Canada, and Norway.
Sale:
Fore Sale Thread
Alpine003
M42 Stroker Kit?
« Reply #11 on: May 14, 2007, 04:39:45 PM »
IMO, with no one exploring the limits of the stock M42 block running a proper turbo system, I think it would be premature to cough up more $ to beef up the bottom end, especially if you only intend to run moderate boost levels.
Jtuner
M42 Stroker Kit?
« Reply #12 on: May 14, 2007, 07:43:29 PM »
Quote from: 2002maniac;25657
ahhh I stand corrected :) Stroke away!!!
shellback
M42 Stroker Kit?
« Reply #13 on: May 28, 2007, 11:49:11 AM »
Volumenforøgelse, Koed M42 2,0L ombygning
DKK 5.995,00
As of today's market currency,
5,995.00 DKK Denmark Kroner    = 1,082.54 USD
United States Dollars
