Author Topic: The mess under the intake  (Read 330612 times)
BlueBMW
« Reply #210 on: February 17, 2010, 07:27:08 PM »
Are you deleting the whole mess or repairing it to stock?  I put mine back to original with all new hoses and it seems great (although I'll probably regret it later).  Also, maybe replace your heater hoses while you're in there.
4banger
« Reply #211 on: February 17, 2010, 07:28:31 PM »
deleting the mess and replacing all other heating and cooling system hoses.
:D:D[SIGPIC][/SIGPIC]
Choking Hazard
« Reply #212 on: February 17, 2010, 11:01:10 PM »
$238.00!!  Pelican is not that overpriced.  Mine was $15.00.  Get the part no from real OEM and stick in the pelican search field
[SIGPIC][/SIGPIC]-Scott
4banger
« Reply #213 on: February 18, 2010, 09:29:27 AM »
Quote from: Choking Hazard;87699
my error was i was looking at the m20 water pipe above the m42 pipe in the catalog. the m20 pipe is $238.25! http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search.cgi?command=show_part_page&please_wait=N&make=BMW&model=BE30§ion=WATpmp&page=5&bookmark=23&part_number=11-53-1-714-738-M200
4banger
« Reply #214 on: February 18, 2010, 11:29:33 AM »
i got the lower intake off today. some how i managed to rip the fuckin wire out of the sensor on oil tower so i gotta rewire that. found out that the vaccum line on my fpr was cracked damn near in 2 at the nipple. that cant be good for performance. the water pipe was broke off in the block. suprised it wasnt leaking. i think im gonna replace all the rubber under the hood with silicone.
BlueBMW
« Reply #215 on: February 18, 2010, 06:34:20 PM »
I was amazed at the difference in smooth running etc when I did the refresh.  The COP conversion may have helped too.  Either way my motor purrs like a sleeping lion.
Redpolack
« Reply #216 on: February 24, 2010, 01:24:41 PM »
no to long ego one of the crazy coolant pipe exploded so I did this set up too it works great for me
Rafiki
« Reply #217 on: February 24, 2010, 02:39:02 PM »
i got a quick question.
this says to go from the valve cover to the throttle body. but the hole that is circled on the throttle body/ intake elbow is plugged... it doesnt even go all the way through. is that normal?
mine did not have a nipple on it like pictures above. its a hole, but at the end of the hole(when looking from the inside, is plugged)
Rafiki
« Reply #218 on: February 24, 2010, 02:51:41 PM »
wow, i got it. it literally goes to the throttle body. the picture threw me off.
Rafiki
« Reply #219 on: February 24, 2010, 03:01:02 PM »
i lied, im still confused. Where does the hose from the valve cover go? straight to the throttle body? or does it go somewhere before it reaches the throttle body
Chalino
« Reply #220 on: February 24, 2010, 05:30:20 PM »
Quote from: Rafiki;88315
Straight to the throttle body; the nipple/connection is on the underside of the TB.
1991 318is
2001 IS300
BlueBMW
« Reply #221 on: February 24, 2010, 06:49:57 PM »
In a pure stock setup doesn't it go through the little combo air / coolant junction hose on its way to the throttle body?
Rafiki
« Reply #222 on: February 25, 2010, 11:19:00 AM »
Quote from: Chalino;88335
the little metal nipple going down at a 45 degree angle? anyone know what size that is? its smaller than everything else
thanks
« Reply #223 on: February 25, 2010, 12:07:26 PM »
EDIT: never mind I was wrong.
« Last Edit: February 25, 2010, 12:13:12 PM by tjts1 »
rennen
« Reply #224 on: February 25, 2010, 08:21:12 PM »
OK, Quick question... Hoping for a clear answer.
Where does the nipple on the bottom of the throttle body connect to? Is it capped or brought in to the Intake Hose?
Thanks
Sal
