Might want to append this PN to the original post (I ordered everything I need EXCEPT these :mad:):
(info from Pelican)
13-64-1-730-767-M213
x8
$1.25 each
You'll need 8 of them if you're going to pull and clean the injectors. They're $5.50 each at the dealer so don't even think about it!!!
Also, do you guys think I'm cool with this coolant hose setup?
I didn't like using a single 5/8" hose because the nipple on the head (kinky!) is smaller. So I used a leftover connector and piece of 5/8"->1/2(?)" hose from the mess. I *think* it'll be OK... everything is snug and the plastic connector and hose look to be in good shape.
