Author Topic: Engine feels sluggish  (Read 5323 times)
denious
« on: May 10, 2007, 07:21:46 AM »
So I decided to perform a full tune-up, and was wondering what I'm missing:
- O2
- air & fuel filter
- plugs
- wires (if the budget allows)
I also found someone talking about:
- cleaning(?) the air intake system
- replacing the ICV (my idle's perfect though, always stays around 800)
- replacing the notoriously bad vacuum lines (what is so notorious about them?)
::: \'91 318iS, like most of us. :) :::
johna
    • My BMW 3 Series Website
« Reply #1 on: May 10, 2007, 10:14:15 PM »
- Oil and oil filter
- Gearbox oil
- Differential oil
- V belts
Wouldn't change the plug wires or ICV unless needed.
Rubber vacuum lines deteriorate with age and heat and allow vacuum to leak usually causing poor quality idle and rough running. Definately worth having a look at.
denious
« Reply #2 on: May 11, 2007, 10:30:28 PM »
The oil and filter are already changed, first thing I did when bought the car. Plugs, V-belts and air filter are now changed too. Will look into the vacuum lines. Is the O2 worth changing or is it only good to diminish fuel consumption?
« Reply #3 on: May 12, 2007, 08:55:01 PM »
It is only good if the car hasn't had one in awhile, and I think they can help with mileage, emissions, and keeping the engine fron running too rich or too lean.
RED IS 91
« Reply #4 on: May 13, 2007, 06:06:01 AM »
I believe if your CO2 sensor isn't working your motor will run in default mode (run rich).It is an important piece of the overall fuel and ignition system.They all work together.
good luck
genna
« Reply #5 on: May 13, 2007, 07:50:25 AM »
I must be blind been trying to find the co2 sensor but just cant see it
________
Buy silversurfer vaporizer
« Last Edit: February 17, 2011, 12:52:45 AM by genna »
« Reply #6 on: May 13, 2007, 08:14:15 AM »
I believe that is supposed to read O2 sensor, since I don't believe we have carbon dioxide sensors on these cars...  although the day is surely coming, thanks to CARB!
genna
« Reply #7 on: May 14, 2007, 12:13:59 AM »
where is the o2 sensor?
________
Aromed Vaporizers
« Last Edit: February 17, 2011, 12:52:54 AM by genna »
genna
« Reply #8 on: May 14, 2007, 12:41:04 AM »
also is there anyway to test it
________
Arizona medical marijuana dispensary
« Last Edit: February 17, 2011, 12:53:03 AM by genna »
RED IS 91
« Reply #9 on: May 14, 2007, 05:15:32 AM »
Quote from: ak96ss;25614
My Bad ,your right ,I meant 02 sensor:o
Alpine003
« Reply #10 on: May 14, 2007, 04:01:24 PM »
Quote from: genna;25670
It is located on your exhaust pipe near the middle of the tranny. As for testing it, if it is totally bad, you're cel will come one with the proper code. Worn out O2 sensors might still work but not efficiently and won't necessarily trigger a cel code. If it's the original sensor or has high miles, it's probably best to replace it if you're noticing poor mileage.
denious
« Reply #11 on: May 14, 2007, 10:04:42 PM »
Cheap O2 sensor found HERE, interesting price compared to $100+ on every other site...
Does anyone have more info on the vacuum lines to change? Pelican sells a lot of different ones HERE.
doucy2
« Reply #12 on: May 14, 2007, 10:50:08 PM »
Quote from: denious;25748
that is a universal o2 so you have to splice some wires. if you get a OE one which is like $108 from fap99 there is no splicing.  I have known of many m42s with bad o2 so it is a good thing to change.
as for the vacuum line look through your engine and find the ones with the most cracking and replace them 1st :)
... no more m42
denious
« Reply #13 on: May 15, 2007, 04:20:15 PM »
What about this one for $80 from RockAuto? It says it's OE type sensor (#11781727451).
Alpine003
« Reply #14 on: May 15, 2007, 05:56:48 PM »
Quote from: denious
Not the same based on the wording.
Just like I have MHW "style" taillights. LOL.
