Author Topic: Oil leaking from Dip stick  (Read 2100 times)
gimpy9195
« on: May 06, 2007, 08:27:47 PM »
anyone seen this before...right near the bottom of the stick tube. or is this oil leak coming from some place else?
« Reply #1 on: May 06, 2007, 08:41:34 PM »
It could be coming from elsewhere, but there are two o-rings that seal the dipstick, so that is probably where it is leaking. I had to replace mine. Unbolt the one bolt at the top that holds it in and give a mighty yank. Watch out for your face.
Replace the o-rings, then shove it back down in there. Worked like charm.
gimpy9195
« Reply #2 on: May 06, 2007, 09:49:27 PM »
thank you!
