I personally recommend the H&R #29964 springs ...or you could go with the newer style H&R 50404 --these pair well with bilstein dampers.
for better handling, more aggressive drop; either IE Stage 3 springs, or H&R race springs
finally, there are a couple of companies (ground control and C3) that make an adjustable coilover kit with adjustable koni dampers and eibach springs set to any rate you want.
You probably have other options in europe, but for us here in the US, the above are common choices.
