Author Topic: What diff do you think this is?  (Read 2518 times)
david220
« on: May 01, 2007, 05:01:31 AM »
Ran across this, supposed to be out of a late '80s e30; has an 'S' stamped in white on the top along with a '54' ; looks like two serial numbers which could be just case part #'s one is 66640 and the other looks to be 1210311 which could be the case BMW part #. The fellow said it was a 4:10 LSD. I am thinking about putting it in my '91 318is; the lower front mounting needs rethreading but other than that seems fine. Thoughts? Looks a bit larger in the rear than the one I took out, so I do not know if it will clear the sway bar. David
jpod999
« Reply #1 on: May 01, 2007, 06:57:25 AM »
There should be a little metal plate on the back of it with a number stamped into it.  If it is a 4.10 LSD then it would say S4.10.  If it is open then it would just say 4.10.  That goes for all the other gearing ratios too.
david220
« Reply #2 on: May 03, 2007, 05:07:29 AM »
It is a 4.10, rethreaded and bolted up; I am going to clean up and go through the old one, shouldn't hurt to have an extra.
david220
« Reply #3 on: May 03, 2007, 07:52:04 PM »
Finished installing the LSD and got the rear springs and shocks done, took it out for a short run to settle things in and there is a noticeable difference with the 4.10. I need to do the front springs and shocks before getting over 3rd so I do not know what happens on the highway. It is a good swap to do for sure. David
nickmpower
« Reply #4 on: May 03, 2007, 08:33:17 PM »
stock is 4.1
jpod999
« Reply #5 on: May 03, 2007, 11:34:15 PM »
What ^^ said.  If you didn't have a 4.10 LSD before, then you probably had a 4.10 Open.
david220
« Reply #6 on: May 04, 2007, 05:00:24 AM »
Yes, I did not have LSD before.
Donkeyshins
« Reply #7 on: May 04, 2007, 01:27:16 PM »
Quote from: david220;25133
Dude, you are so missing out...trails, beautiful trails...:D
