Author Topic: H&R springs  (Read 8843 times)
mirage
H&R springs
« on: April 30, 2007, 03:12:45 PM »
H&R spring
Hi, i was wondering if any H&R spring owners can help me identify this spring, its a red color H&R spring with (BMW 3/1 VA) wording.pls help
sha1234
H&R springs
« Reply #1 on: April 30, 2007, 09:10:38 PM »
theseuns?
they are the H&R sport springs lower the car about 1.25 front and rear
i like mine... but soon should be going to IE stage 3's
Tonyb
H&R springs
« Reply #2 on: April 30, 2007, 09:16:09 PM »
Quote from: sha1234;24887
theseuns?
Why are you changing them?
EducatedFool
H&R springs
« Reply #3 on: April 30, 2007, 09:23:21 PM »
if i had to guess......
IE's are stiffer, offer a lower stance, and overall better performance
btw, when you're done w/ those H&R's, i'll be glad to take them off your hands :D
sha1234
H&R springs
« Reply #4 on: April 30, 2007, 09:55:15 PM »
heheh thats just what i want to hear
they are mint... they got maybe 4,000 KM... not miles... KM im all canadian and such :)
but yeah... the plan is so that 2 in the front and 1.5 in the rear will fix that front to rear fender gapping that i dont like to see... cause im planning on getting a set of CR7's so i want to have a good clean pretty even gapping
and i mean they are too expensive so y not
Tonyb
H&R springs
« Reply #5 on: May 01, 2007, 01:06:32 AM »
What about the ride for a daily driver with the IE's.
mirage
H&R springs
« Reply #6 on: May 01, 2007, 02:01:56 AM »
thanks....so i guess these are 50404's for the 318is....but just curious,how do we differentiate the 50404's and the 50406?is there a indication on the springs??
Bunta
H&R springs
« Reply #7 on: May 01, 2007, 07:30:41 PM »
Quote from: Tonyb;24912
Its a aggressive street setup. I have it on my 325 and love the way it handles.  It rides fine on the street as well.  The only problem is I wish the front was a tad lower.
I like a 60/40 drop.  The IEs need to go an inch higher in the back and an inch lower in the front for a perfect raked stance. but as they are they work well and give you great oil pan clearence up front(a big plus since im going M50)
KW makes a 60/40 kit but there too soft for my liking.  A 60/40 with bekkers spring hats up front is the perfect setup for the "euro stretch" look.
Hunter
mikesjo
H&R springs
« Reply #8 on: May 01, 2007, 10:57:54 PM »
theseuns?
If you're gonna get rear shock mounts, get better ones than those. IE or GC for example.
sha1234
H&R springs
« Reply #9 on: May 01, 2007, 11:36:12 PM »
i did
those where just the front mounts... i needed something to tie me over till adjust camber plates etc
i got the turner high performance aluminum/rubber mounts
http://www.turnermotorsport.com/image/suspension/susp_e30_mount_kit_lg.jpg
the ones on the far right... it came as a package for pretty cheap so thats y i got just the standard front mounts
mikesjo
H&R springs
« Reply #10 on: May 02, 2007, 02:08:25 AM »
Good stuff :).
mirage
H&R springs
« Reply #11 on: May 02, 2007, 08:13:21 AM »
sorry but i think this thread is going off topic....can someone ans my question rather than having your own disscussion....tq
Febi Guibo
  • m42 reporter
H&R springs
« Reply #12 on: May 02, 2007, 08:54:31 AM »
to me, they look like #29964 springs... I know H&R changes their colors etc but the later style springs have the number eg: 50404 etc...
(I have the #29964 springs, they work great)
Support M42club.com !!
mirage
H&R springs
« Reply #13 on: May 02, 2007, 11:16:29 AM »
thanks febi...i think that will do...
b318isp
H&R springs
« Reply #14 on: May 02, 2007, 11:42:20 AM »
I had the 3/1 but they are too stiff and too low at the front. On track I found the car wandering a lot/difficult to balance and on the street the front regularily bottomed out. Additionally, I damaged the wing when I spun on track on full opposite lock. The wheel was driven in the the top of the wheel arch when a crossed a kerb :mad: . I have now changed to 5/1 and am very satisfied.
The 5/1 have an extra coil up front and as a result lowers the car about 40mm. The 3/1 dropped the front about 60mm.
See:
http://www.esatclear.ie/~bpurcell/low3hrminus60.jpg
http://www.esatclear.ie/~bpurcell/318ismods.html#suspension
« Last Edit: May 02, 2007, 11:45:35 AM by b318isp »
