Yeah that's the real issue to balance here. The Motronic is not designed to run lean like that, so it will not advance the ignition timing much at all during cruising. That eliminates the big problem with detonation and blown pistons/valves. At the same time, it might end up requiring me to use more gas to maintain enough power. It will be interesting to see how this goes.
I am actually thinking of changing the thing, assuming it works. I might do a directly scalable AFR deal, dependent on TPS. Like 19:1 t 0% throttle and 16:1 at 40% with adjustable AFR targets based upon the TPS between that range. Above 14:1 it will just run what it is programmed to normally.
