Author Topic: Strange sound when clutch is pressed in  (Read 3027 times)
automatic
« on: April 24, 2007, 10:24:52 PM »
When the clutch is pressed in there is a slight vibration in the pedal and a noise that sounds like a loose belt spinning. When I release the clutch pedal the noise goes away.
The noise is audible in neutral or any gear, its not too loud, I don't notice it unless the windows are down. I just noticed this a couple days ago and as much as I've been looking for an excuse to get a lightened flywheel i'd rather not have to do any major work right now. Any thoughts?
« Reply #1 on: April 24, 2007, 10:43:34 PM »
Throwout bearing gets my vote.
jetteman
« Reply #2 on: April 24, 2007, 11:15:54 PM »
i second the throwout bearing.
ten2doyle102
« Reply #3 on: April 24, 2007, 11:23:25 PM »
i would have to agree as well.  is it the original clutch or did you recently have it replaced.
Pedro
    • http://www.realoem.com/bmw
« Reply #4 on: April 25, 2007, 12:12:49 AM »
throwout bearing x4
automatic
« Reply #5 on: April 25, 2007, 12:45:58 AM »
If the throwout bearing is the problem, what does that mean to me in the short term? Is this something I should get in to a shop asap to have looked at or is it something that I can let ride? Also what would be involved for repair?
b318isp
« Reply #6 on: April 25, 2007, 05:23:46 AM »
You're looking at a new clutch kit. Plan for doing it in the near future as the bearing can be noisy for a while without being a problem.
