Author Topic: just installed a handsfree carkit but have a question?  (Read 3114 times)
genna
« on: April 24, 2007, 01:56:24 AM »
Hi as the heading says just installed a handsfree bluetooth carkit much easier than I thought and worth doing the only issue I had was the mike wire up the pillar between the front door and windscreen I am unsure how to remove the panel is it on clips, I really would love a heads up so I dont break anything.
any help appreciated
________
MARIJUANA TEST
« Last Edit: February 17, 2011, 12:52:21 AM by genna »
FL318is
« Reply #1 on: April 24, 2007, 07:23:10 AM »
Its been so long since I have removed that piece, I forget.  I always go to realoem.com and use the schematic as a guide.
peteM3power
« Reply #2 on: April 24, 2007, 06:31:03 PM »
I did this a while ago.  Simply peel the rubber away that is tightly attached to the door lining (so the rubber on the door side of that panel, not the windscreen side) and there should be plenty of space for you to thread your wire through.  I had mine go under the steering column, up past the headlight, foglight switch then up there inside behind that panel all the way to near opposite the sunroof.
I just peeled the rubber back, threaded the wiring through and then carefully pushed it all back in so that it didn't bend the headlining back and so that it closed with a perfect seal.
I hope this helps,
Pete
genna
« Reply #3 on: April 24, 2007, 11:11:47 PM »
thanks alot mate I did pull on it but it was really tight felt glued so i thought before i break it i better ask.
________
MEDICAL MARIJUANA
« Last Edit: February 17, 2011, 12:52:30 AM by genna »
peteM3power
« Reply #4 on: April 26, 2007, 08:20:45 AM »
No worries.  I guess you retried it and it came off alright.  And yeah, fair enough, it never hurts to ask as chances are there is someone on the forum who has done it already!
Cheers, Pete
