Author Topic: Idle control value  (Read 2255 times)
dlmrun2002
Idle control value
« on: April 19, 2007, 07:25:11 PM »
Well  engine  runs great ( New rebuilt )  but idle is poor. Looking for ohm value on idle control valve across  the two lead  connectors. I'm reading 8 ohm  and when I vary the valve it seems to go down a bit but comes back up to 8 ohm value even with valve in different position. This seems wrong. Purcell said value  is 4 ohms. Is this right?  Thanks
DLM
b318isp
Idle control value
« Reply #1 on: April 23, 2007, 07:20:51 AM »
Quote from: dlmrun2002;24087
DLM
The M42 ICV is electrically actuated and spring returned. I'm not sure of the exact method of control, but a fixed impedence may be satisfactory. What are the symptoms of the bad idle?
