Author Topic: SES light being a whore  (Read 2275 times)
maxwellredrum
« on: April 17, 2007, 10:28:49 PM »
hey guys long time no posting , been really buisy in school here. I am having an issue, i had to replace the fuel lines under the intake manifold, and once it was all put back together the car ran great, although the damn ses light is on. ive gone over everything even tried to diagnose the signal with the gas pedal thing but the light stays on the entire time and does not flash. the ONLY thing i have found that is different is that the vac line going to the FPR is crushing once the motor is started but i dont think that would cause ses because for months the car didnt have the fpr hooked up and only occasionally did the light flash, and when i burped the gas it went away. this time its not going away. thanks guys PLEASE help, ive reset teh ecu about 4 times, rechecked all gaskets ETC and cannot figure it out and rechecked all vac lines. thanks all
-Max
e9nine
« Reply #1 on: April 18, 2007, 08:01:03 AM »
SES :confused:
Are you talking about the SRS or the Check Engine light?
maxwellredrum
« Reply #2 on: April 18, 2007, 11:50:51 AM »
service engine soon light...check engine yes
Alpine003
« Reply #3 on: April 18, 2007, 09:33:29 PM »
Get a code reader or go to Autozone to have them pull the code. That should be the first thing you do before making any blind assumptions.
e9nine
« Reply #4 on: April 18, 2007, 09:40:28 PM »
I gonna guess and say you have either triggered a vac. leak while working in the nest of hoses down there.
