Yes, I finally mounted them. With the part time job (to fund the addictiction) I don't have much time.
I did it in phases.
Phase 1 - clean the openings
Phase 2 - find black vinyl. I used this because the opening between the lense and tag filler was wide enough to see alpine white.
Phase 3 - paint the tag filler. It was already fading from FL sun.
Phase 4 - apply black vinyl. The secret is to get it misted and wet.
Phase 5 - cut the tag. So the tag did not extend below the tag filler. I cut, folded and drilled it. Now the tag rides about 8mm higher.
Phase 6 - Becks
Phase 7 - Install.
PICS to FOLLOW The lighting was too low to get a clear pic. I will take one tomorrow and post. For now here is a in progress shot with good sunlight.
