Author Topic: OEM Seperates Upgrade Help  (Read 10746 times)
Vladi
    • http://www.bmwzone.ro/forum
« Reply #15 on: August 05, 2007, 02:59:01 AM »
Well just take out the black plastic panel behind the mirror and look. :)
I don't know about US spec, but in Yurp only 6cyl were prewired for the tweeters and other stuff and some late 4cyl. Example: just looked around at a 318is '90 brought from .de wich was prewired for A/C, headlight wipers, tweeters, etc. :)
On the other hand my 316i wich is also from 08/90 was prewired for absolutely nothing!:mad:
« Last Edit: August 05, 2007, 03:03:06 AM by Vladi »
« Reply #16 on: August 06, 2007, 01:08:09 PM »
so glad I have "premium" audio :)
christophbmw
« Reply #17 on: August 06, 2007, 07:18:59 PM »
Quote from: Eurospec;31073
^^ anyone?
ya the wires ar there, i think they are yellow/gray and green/gray but not sure. they come out near the kickpanel speakers and i spliced into tem there for the aftermarket cross-overs......that way i didnt have to run seperate wire through the door wiring harness boot, i just used the factory wire :). if you have anymore questions i would be glad to help.
Royalratch
Door Tweeter Mystery...
« Reply #18 on: February 19, 2008, 08:15:00 AM »
Quote from: christophbmw;31155
I've just done this and I can only find one of the wire strands from the mirror loom.
They definitly come out behind the kick speaker but I just can't find one!
Also, whilst doing this I screwed up my light delay rely and can't remember how it should be wired to use the relay again!
Royalratch
« Reply #19 on: February 19, 2008, 09:19:39 AM »
Hello all.
I've been checking the help section here to make sense of the mess of wiring I've found in my footwell. Basically, I'm trying to install those A-pillar tweeter pods
and at the same time figure out why interior light delay isn't working.
As it stands, this where I'm at:
Tweeter Pods
Door tweeter pre-wiring is present (Grey/yellow & Grey/Green)
Down in the footwell, the only thing resembling what could be the tweeter terminations are these:
Grey and LIGHT Green & Brown and Blue - NOT what's up at the A-Pillar tho...
This plug is also lurking around down there:
And this too:
Having wired in the crossover, I get no sound from the tweeter when using the door wiring and various terminals. I do get sound if I go direct to the crossover but
I want to splice into the existing loom so I don't have to take the door/trim apart - the door loom looks packed tight anyway.
Interior Light Delay Prep
I've wired the door relay as directed by various threads in the help section. This is what I have done:
Brown/Purple plugged together and just the single Brown/Yellow to Door switch - is this correct?
The interior lights work fine, just no delay - maybe the relay I bought is duff. Anyway to check?
« Last Edit: February 20, 2008, 01:10:23 PM by Royalratch »
Royalratch
« Reply #20 on: February 19, 2008, 01:25:20 PM »
I've just learned that tweeter wire change colour between the mirror and the footwell! Why on earth would they do that!?
Anyone know what they change to?
Royalratch
« Reply #21 on: February 20, 2008, 08:08:26 AM »
Anyone?
Royalratch
« Reply #22 on: June 08, 2008, 05:52:17 AM »
STILL haven't figured this one out guys.
Don't make me pay some ICE guy big dollars just to sort this out!
///m42 sport
« Reply #23 on: December 11, 2010, 11:52:00 PM »
did anyone answer the OPs question about the crossovers built into the kickpanel speakers?
hammoj28
« Reply #24 on: February 26, 2012, 07:31:35 AM »
Dunno, but I know that from having a look at mine the two wires are definately there for the tweeters. The green/grey is there and the yellow and blue one is folded back and taped up in the loom. has a blue plug on it......
