Author Topic: Serious issues, tapping/clickin, big leak  (Read 3423 times)
doucy2
« on: March 25, 2007, 07:48:53 AM »
Well the other day I started up my car and I hear this redickulas racket, tapping/clicking noise, it would worsen upon acceleration. I ended up putting some more oil in but the noise just got a little fainter. It did NOT go away. Then I wake up this moring and find a MASSIVE PUDDLE of oil under the car .
I will climb under there this afternoon to see where it all came from. I know for sure there is a small leak in the top to the pan, but the puddle was huge.
Anyone have some insight.
... no more m42
Febi Guibo
  • m42 reporter
« Reply #1 on: March 25, 2007, 09:25:02 AM »
could be a profile gasket, but... pull the lower oil pan and let us know what you find...
Support M42club.com !!
doucy2
« Reply #2 on: March 25, 2007, 09:39:05 AM »
crawled under it and it looks to be leaking from the timing case and the whole passenger front side of the pan is covered in oil.
that gasket wouldn't explain the ticking noise though?
... no more m42
M42Iberia
« Reply #3 on: March 25, 2007, 11:13:26 AM »
a pretty bad leak that i had appeared to come from the timming case but later found it to be the gasket to the oil filter housing. good luck
sheepdog
  • Site Admin
« Reply #4 on: March 25, 2007, 03:32:26 PM »
Profile gasket deals with little oil.
Could be the front main seal or the timing chain tensioner.
There are gaskets covering the timing chain on the front, but same as the profile, they deal with only a little oil.
Otherwise, the only places really left is the head gasket (unlikely) or the gasket between the block and the timing case. (LOADS of fun!)
b318isp
« Reply #5 on: March 27, 2007, 06:29:22 AM »
It could be a collapse of the timing case idler sprocket. The casting breaks just where the sprocket bolts in. I'd pull the timing case covers before you do another thing.
doucy2
« Reply #6 on: March 27, 2007, 08:33:18 AM »
yea well thanks for all the help guys, still havent towed her yet.  i am really considering becomming a trator and do a m50 swap.
... no more m42
sheepdog
  • Site Admin
« Reply #7 on: March 27, 2007, 11:03:39 AM »
Quote from: doucy2;22278
Thats ok, I keep thinking of dropping in an Ecotech.
« Reply #8 on: March 27, 2007, 11:57:15 AM »
Well, you could always dump in a few quarts of oil and start it up...get under it & look for the source?  I'd say it is either the timing chain tensioner or the gasket between the timing case & block.  Those are the 2 big high pressure spots over on the passenger side.  GOOD LUCK!
