Author Topic: Oil supply/return for turbo: how without drill pan? and oil-cooler is needed?  (Read 3041 times)
nuvolarossa
Hi, how can be send the oil from engine to the turbocharger?
And what can be done for return line without drill pan/block?
Do you know how Mosselman kit do this?
Can the return line go to the oil-filler cap with a scavenge pump? And what for supply-line?
With a turbo at 7psi on M4x, is needed a oil cooler?
My car is a E36 M44, so I have the plastic oil filter cover, not the metallic as M42.
thank you
« Last Edit: April 23, 2007, 06:44:04 AM by nuvolarossa »
