Downing Atlanta Supercharger (DASC)
Author Topic: Downing Atlanta Supercharger (DASC)  (Read 23324 times)
hesgone2fast
« on: March 19, 2007, 04:55:36 PM »
Has anyone tried to contact DA lately? Because I have been sending them emails for a week now with no reply... I live in Spain, and a call overseas might be kindda expensive.If someone could call them to ask if they sell it for the E30, I would really appretiate it. I want to buy a kit for my E30, does anyone know if it´s allready available?
 Thanks a lot guys.
doucy2
« Reply #1 on: March 19, 2007, 05:32:39 PM »
no they dont do one not the the e30 m42, they do one for the e36 though, however i am not positive on these conclusions.
... no more m42
mdiddy
« Reply #2 on: March 19, 2007, 07:02:11 PM »
the downing e36 kit WILL fit the e30 grassroots did it.
1991318is
« Reply #3 on: March 19, 2007, 08:36:42 PM »
doesn't their add in Bimmer and Roundel show a e30 m42? I was under the impression that I had read they built one for the e30 m42.
RP Kennedy
« Reply #4 on: March 19, 2007, 09:02:20 PM »
Not only did they build a kit for the E30 M42, it was detailed in Grassroots Motorsports in 3 or 4 issues last summer and discussed / copied on this very site!  Let's stick with the facts hombres.
Tonyb
« Reply #5 on: March 19, 2007, 09:27:44 PM »
Anyone know how much $$$
1991 E30 M42
Dasc
« Reply #6 on: March 19, 2007, 10:40:16 PM »
Shocker has a Supercharger on his E30, but I'm not sure if its DA or not.
fabe
« Reply #7 on: March 19, 2007, 11:05:39 PM »
Quote from: 1991 E30 M42;21737
That looks like a custom set up rather than the DASC...
hesgone2fast
« Reply #8 on: March 20, 2007, 01:20:31 AM »
thanks guys. what grassroots did was modify the kit form the e36, the biggest problem they had was the serpentine belt system versus the v-belt system on the e30. I have a full system of serpentine belt system, taken out of an e36. so I should not have a problem with that. But my main problem would be not having knocking sensors as the e36. I also know that the DASC leaves a lean mixture on the engine. So if I improve the mixture through remapping, would I still have knocking?
 By the way, DA website is not working for me since last night, does it work for you?
http://www.understeer.com sells a diferent supercharger system than DA, that´s the system on the picture above.
« Last Edit: March 20, 2007, 01:23:02 AM by hesgone2fast »
Tonyb
« Reply #9 on: March 20, 2007, 01:30:47 AM »
That looks like a standard belt on the s/c pulley?
Shocker
« Reply #10 on: March 20, 2007, 06:43:32 AM »
Quote from: Tonyb;21753
Yes it is.  If done correctly it works fine.
stuartgallafant
« Reply #11 on: March 20, 2007, 07:02:39 AM »
this is an eaton m52 s'charger, used on 2.0-3.0 litre engines. i have an eaton m40 s'charger from the MINI Cooper S sitting in my shed that i was gonna use
this one in the pic, does not seem to have any intercooler. if i had a 'charged engine, i would want to use an IC. maybe this guy is using laminova's?
hesgone2fast
« Reply #12 on: March 20, 2007, 06:08:26 PM »
I would like Shocker to write his opinion on his kit, and if he has had any detonation problems.
 An intercooler would be way too difficult to install on a supercharger system, due to the limited space and the position of the manifold. besides a supercharger only raises the intake temperature by 60-70F  compared to a turbo is nothing.
Shocker
« Reply #13 on: March 20, 2007, 08:42:38 PM »
Quote from: hesgone2fast;21849
Well since you will never find someone to make this kit id say go with the Downing Atlanta Kit, then all you have to do is swap over to the e36 pulley system and get a remote brake reservoir from the 2002 which I have on my car and whatever else GRM did.  As for detonation I have an audible knock sensor on my engine so I know when it happens.  I’m running stock timing right now but I’m running 100 LL octane only because I can get it cheaper then 92.  (My dad has an airplane)   but I do need Adjustable timing because I won’t boost past the middle of 4th gear it starts knocking at 12PSI on stock motor.
« Last Edit: March 20, 2007, 08:55:50 PM by Shocker »
gundy318
« Reply #14 on: March 20, 2007, 09:10:17 PM »
Quote from: RP Kennedy;21719
could somebody repost that issue on this thread?
