DME pins?
Author Topic: DME pins?  (Read 7369 times)
DME pins?
« on: March 19, 2007, 03:54:31 PM »
I am going to wire the MS to the factory harness so I need to know what the 88 pins on the ecu's plug are for.  Does anyone have that info?  I looked around and couldn't find anything.
DME pins?
« Reply #1 on: March 19, 2007, 10:40:46 PM »
anyone?
Tonyb
DME pins?
« Reply #2 on: March 20, 2007, 02:03:33 AM »
Sorry dude, I did my best. BMW's North America site has a ? section though! I bug them all the time!
m44power
DME pins?
« Reply #3 on: March 20, 2007, 11:40:06 AM »
pin 88 is for DLC data link connector its is an output signal with ignition ON
DME pins?
« Reply #4 on: March 20, 2007, 12:02:11 PM »
cool do you have the info for all the pins?
m44power
DME pins?
« Reply #5 on: March 20, 2007, 03:23:08 PM »
yes i have all the pins and wiring diagrams ask me for everything you want i cant post it here coz its lot of work and i dont have the time
m44power
DME pins?
« Reply #6 on: March 20, 2007, 03:28:07 PM »
OHH just a moment are you looking for a complete pinout ? i was thinking that you looking only pin 88 :D if you need complete pinout im gone post it for you :)
DME pins?
« Reply #7 on: March 20, 2007, 03:39:59 PM »
awsome thanks!
m44power
DME pins?
« Reply #8 on: March 20, 2007, 04:29:45 PM »
Pin  Signal     Descripion
 1   E->        Fuel pump  Relay
 2                Not Used
 3   E->        E30 Injector 1 & 3  / E36 Injector 2 & 4
 4                Not Used
 5                Not Used
 6   E-          Earth
 7                Not Used
 8   ->          Spare Cable
 9                Not Used
 10              Not Used
 11  ->         Transmission Control Module (TCM) - Some Models (Automatics)
 12  <-         Throtlle Possiton Sensor (TPS)
 13              Not Used
 14  E-         Volume Air Flow Sensor (VAF)
 15  <-         Knock Sensors 1 & 2
 16  <-         Camshaft Possition Sensor (CPS)
 17  ->         Instrument Panel & Trip Computer / Transmission Control Module (E36)
 18  E->        Intake Manifold Air Control Solenoid
 19              Not Used
 20              Not Used
 21              Not Used
 22              Not Used
 23              Not Used
 24  E->       Ignition Coil Cylinder 3
 25  E->       Ignition Coil Cylinder 1
 26  <-         Battery
 27  E->       Engine Control Relay
 28  E-         Earth
 29  E->       Idle Air Control (IAC) Valve
 30              Not Used
 31              Not Used
 32  E->       E30 Injectors 2 & 4 / E36 Injectors 1 & 3
 33              Not Used
 34  E-         Earth
 35              Not Used
 36  E->       Evaporative emission Canister Purge Valve (EVAP)
 37  E->       Oxygen Sensor Heater Relay
 38              Not Used
 39              Not Used
 40              Not Used
 41  <-         Volume Air Flow (VAF) Sensor
 42  <-         Knock Sensor 3 & 4
 43   E-        Engine Cooland Temperature (ECT) , Knock Sensor , Throtlle Possition Sensor (TPS)
 44   <-        Camshaft Possition Sensor (CMP)
 45              Not Used
 46              Not Used
 47              Not Used
 48   ->       E36 A/C Compressor Clutch Relay
 49              Not Used
 50              Not Used
 51  E->       Ignition Coil Cylinder 4
 52  E->       Ignition Coil Cylinder 2
 53              Not Used
 54  <-         Engine Control Relay
 55  E-         Earth
 56  <-         Ignition Switch
 57              Not Used
 58              Not Used
 59  ->         Throtlle Possition Sensor (TPS) , Volume Air Flow Sensor (VAF)
 60  <-         Data Link Connector (DLC)
 61              Not Used
 62              Not Used
 63              Not Used
 64  <-        Transmission Control Module (TCM)
 65  <-        Transmission Control Module (TCM)
 66              Not Used
 67  <-        Crankshaft Possition Sensor (CKP)
 68  E-        Crankshaft Possition Sensor (CKP)
 69              Not Used
 70  <-         Heated Oxygen Sensor (HO2S)
 71  E-         Heated Oxygen Sensor (HO2S)
 72              Not Used
 73  <-         Instrument Panel
 74  ->         A/C Control Module - If Fitted , Data Link Connector (DLC) , Instrument Panel
 75              Not Used
 76  <-         Volume Air Flow (VAF) Sensor
 77  <-         Intake Air Temperature (IAT) Sensor
 78  <-         Engine Coolant Temperature (ECT) Sensor
 79              Not Used
 80              Not Used
 81  <-         E36 Alarm System Control Module , Trip Computer
 82              Not Used
 83              Not Used
 84              Not Used
 85  <-        A/C Refrigerant Pressure Switch
 86  <-        A/C Control Module
 87  <-        Data Link Connector (DLC)
 88  ->        Data Link Connector (DLC)
     ->  = Output Signal
     <-  = Input Signal
     E-  = Earth
     E-> = Output Signal Volts
OK It Cost Me 1 Hour And 43 Minutes (and some seconds :p) but There You Go ! If you need more just ask for it ;)
This is the terminal side pinout picture :
« Last Edit: March 20, 2007, 04:32:45 PM by m44power »
DME pins?
« Reply #9 on: March 20, 2007, 04:43:41 PM »
ha hats off to you!
m44power
DME pins?
« Reply #10 on: March 20, 2007, 04:48:16 PM »
For repay me just send me a pic of your setup ;) cheers
DME pins?
« Reply #11 on: March 20, 2007, 04:48:43 PM »
Quote from: m44power;21836
sure thing :D
xsjado
DME pins?
« Reply #12 on: March 30, 2007, 03:24:09 AM »
pin 81 green!!connection to ews!!
m44power
DME pins?
« Reply #13 on: April 01, 2007, 06:39:50 AM »
Quote from: xsjado;22505
81 <- E36 Alarm System Control Module = EWS , Trip Computer
