Cooling Problem
Author Topic: Cooling Problem  (Read 4163 times)
HarrisonS
Cooling Problem
« on: March 19, 2007, 02:34:32 PM »
Hey guys,
I just got a 1991 318is about 3 months ago, and it has been running great.  But about week ago i noticed it was running a bit hot (3/4 mark) and then in the last couple days it has been completely overheating (hitting the red).  It seems to be slowly losing water, although I cannot see where the leak is.  I have refilled it with water and drove it around a bit and it still overheats within a mile or so.  When I turn on the heat, cool air comes out of the vents.  I also checked the oil and there is no water or coolant in it.  Any ideas? Bad thermostat?
e9nine
Cooling Problem
« Reply #1 on: March 19, 2007, 02:57:01 PM »
Welcome!
Be careful at this point as a warped head/blown headgasket could be lingering  around.
I'd say to let the car sit at idle for a couple of minutes with the hood open, pay attention to the vital locations; hoses, water pump, thermostat housing, radiator and try see if any leaks pop up.
I'll let others chime in on extra tips...
Cooling Problem
« Reply #2 on: March 19, 2007, 03:01:15 PM »
sounds like you tstat is stuck closed.  it could be the water pump though.
HarrisonS
Cooling Problem
« Reply #3 on: March 19, 2007, 03:16:58 PM »
I've been keeping an eye on the leak for the past couple days and it seems as if some days it leaks more than others.  Yesterday, with a cold engine I started it up and let it run and I could see no leaks or water dripping, but later that day I drove it about a mile to see what it would do, and when I got back to my house it was low on water, and so I filled it again and didn't drive it.  This morning I looked at it and it was low again, but there wasn't a whole lot of water on the ground
e9nine
Cooling Problem
« Reply #4 on: March 19, 2007, 03:25:30 PM »
We need to identify the source of the leak now that we know it leaves a trace... I'd avoid driving the car if I was you at this point. Our aluminum heads  warp easily
Cooling Problem
« Reply #5 on: March 19, 2007, 03:36:21 PM »
Sounds to me like something is clogged, and the pressure is probably pushing it out of a crack in a line. If it isn't leaving a trail, look near hot items, i.e. headers, which could cause the water to evaporate quickly. I have no idea if any cooling lines run near there though...
tstat is probly the best bet, my family's E34 had a bad one, with similar symptoms
good luck, hope it's nothing serious
HarrisonS
Cooling Problem
« Reply #6 on: March 19, 2007, 05:34:07 PM »
How hard is it to replace the tstat?  Do I need any special tools?
e9nine
Cooling Problem
« Reply #7 on: March 19, 2007, 05:41:43 PM »
Quote from: HarrisonS;21701
Luckily the thermostat is one of the articles on our very own "Zoso's" site
http://zoso.no-ip.org/cars-318i.html
Tonyb
Cooling Problem
« Reply #8 on: March 20, 2007, 01:48:27 AM »
Make sure you bleed the radiator!
Choking Hazard
Cooling Problem
« Reply #9 on: March 20, 2007, 07:48:16 AM »
Removing the fan shroud makes t-stat replacement MUCH easier.  What is the proper torque spec for the housing?
[SIGPIC][/SIGPIC]-Scott
HarrisonS
Cooling Problem
« Reply #10 on: March 20, 2007, 01:19:00 PM »
I am confused on what all is involved in "bleeding" the system.  Are there more steps than just emptying all the coolant from the engine and the radiator?
e9nine
Cooling Problem
« Reply #11 on: March 20, 2007, 03:25:31 PM »
Quote from: HarrisonS;21816
Yes there's a bleed screw used to relieve pressure gradually so air bubbles/pockets aren't in the cooling system.
Here's an excerpt
[SIZE=+1]Bleeding[/SIZE]        Radiator mounted expansion tank:
                    1. Loosen the bleed screw on top of radiator expansion                      tank and let the coolant flow out as you pour it in the                      reservoir. Tighten the screw when the flow out is free of                      air bubbles.
                    Separate expansion tank:
                    1. Loosen the bleed screw on top of thermostat housing                      and let the coolant flow out as you pour it in the reservoir.                      Tighten the screw when the flow out is smooth and free of                      air bubbles.
                   2. Set the temperature setting to full warm and start engine.
                    3. When the car is going to reach his normal temperature you                      might going to need to add more coolant. Always check the                      coolant level.
                    4. With engine idling at normal temperature, open the bleed                      screw and tighten it when coolant is spilling out smoothly                      and free of air bubbles.
                    5. Repeat bleeding, and again and again.
                    6. Do it a few times to avoid overheating.
Choking Hazard
Cooling Problem
« Reply #12 on: April 05, 2007, 10:44:29 PM »
The "bleeeding" is different from "flushing".  Bleeding is just done at the end to get out air bubbles.  If you read the above thinking "flushing", it sounds like you do this to add new coolant.
BrandC
Cooling Problem
« Reply #13 on: April 05, 2007, 11:38:19 PM »
You can do a leak down test as well if you suspect coolant leaks. This is just a mock radiator cap that can be pressurized with air to simulate pressure in the coolant system. If you see anything leak, that's your culprit.
If there are no leaks on the leak down system, you probably have air in the coolant system.
rhogg
Cooling Problem
« Reply #14 on: April 06, 2007, 01:11:57 AM »
The first thing to do before you start pulling things apart is to try to find the leak. At idle you might not be able to see the leak. Rev the engine and pay close attention to the top passenger side hose.  A cracked rad neck is common.
