Engine Probs...
Author Topic: Engine Probs...  (Read 6600 times)
Engine Probs...
« on: March 19, 2007, 10:24:50 AM »
Well this past week was my spring break and I went to the beach. Before I left I took off the full exhaust and front sway bar. I was test fitting the turbo manifold. I left the car in the air while I was at the beach. I left the turbo manifold on but I capped it off so nothing would get in my engine while I was gone. BTW the car was parked inside a garage the whole time.
Well I get back from the beach and put the exhaust and sway back on. I also rewired the reverse lights since the guibo took the wires out. I went to start it up and it fired right up but it sounds like a wrx when you hit the gas now....
The check engine light isn't on or anything. The car feels fine below 5k. Above that it feels like I'm missing some power. I'm guessing that it may be one of the gaskets is missaligned? But that still doesn't explain why the top end feels weak. I'm pretty sure its running rich too, its deff eating a lot more gas. I pulled the plugs and they are fine. I do think my o2 is on the way out but would it make a differance like this?
I'm just confused as to what it is since the car was fine when I pulled it into the garage. Is the car just mad that I didn't take it to the beach too?? :rolleyes:
badboypolar
Engine Probs...
« Reply #1 on: March 19, 2007, 11:07:39 AM »
Sounds like the O2 is either bad, damaged or unpluged.
Engine Probs...
« Reply #2 on: March 19, 2007, 11:10:27 AM »
It may very well be mad, who knows.
If it is louder than before, maybe you forgot to put the gasket in after the header?  Check the cat-back flange too.  Sounds pretty odd.
e9nine
Engine Probs...
« Reply #3 on: March 19, 2007, 11:13:51 AM »
Did you unscrew the O2 sensor at the port of directly off the downpipe?
The gaskets for the exhaust drop off easier and can go unnoticed. It sounds more like a case of either, a gasket, you didn't connect the exhaust back the right way and it's loose or you have sprung a leak/cracked something along the exhaust flow path.
Engine Probs...
« Reply #4 on: March 19, 2007, 01:31:53 PM »
yeah I did remove the o2 sensor when I took of the exaust.  I only unscrewed the exhaust at the head and the bottom of the manifold.  I took the whole back off in one peice.  So I guess that leaves me with the exhaust manifold's top and bottom gaskets.  Everything should be tight but I should double check.
So would a bad o2 kill the top end power?  I can get up to 7k but it seems slower to get there and it deff doesn't feel as strong up there as it did before.
I do know for sure that all the gaskets are on there.  I made sure that they didn't fall off when I was putting everything back together.
Tonyb
Engine Probs...
« Reply #5 on: March 19, 2007, 10:03:50 PM »
I had the same problem with a bad o2, but it was'nt any louder. Maybe you have a leak and a bad o2? By the the way happy B-day you old fart! (your only 3 years older than my son!) With a bad o2 the computer can't tell how rich or lean the motor is running, so you get poor mileage and performance.
« Last Edit: March 19, 2007, 10:08:48 PM by Tonyb »
Engine Probs...
« Reply #6 on: March 19, 2007, 10:14:19 PM »
lol thanks, for some reason 20 seems really really different.  I have an AEM wideband that I am going to install after I figure out what the pins on the DME are so I can wire the MS into the factory harness.  :)
Tonyb
Engine Probs...
« Reply #7 on: March 20, 2007, 01:44:04 AM »
That won't help your o2 problem. If it's ready to go then it won't be a waste, since you need one, will it?
maxwellredrum
Engine Probs...
« Reply #8 on: March 31, 2007, 10:25:21 AM »
mine was having the same problem, everyone was like wtf did you do sounds like a subaru! turns out one of the ground wires to my coil pack had let go and only made contact intermittently....just food for thought.
-Max
318is91
Engine Probs...
« Reply #9 on: April 03, 2007, 05:30:41 AM »
have a friend hold a balled up rag over the exhaust outlet and look for leaks if you have a leak before the o2 sensor it could be either drawing in fresh air or letting exhaust out either way it could mess up the o2 reading and there for fuel and this could be exaggerated at high rpms. ie a higher percentage of exhaust is forced out the leak because theres more pressure, so the 02 sensor isn't affected by the lost fumes, the car sees too little exhaust, it thinks it isn't burning enough fuel for that rpm ie it thinks it is running lean and dumps in fuel too compensate.
so all that too say yes it could be just a exhaust leak before the 02 sensor
hope that helps
ps also a bad 02 sensor could do the same thing... and they all work essentially the same so you can use a o2 sensor from practically any car so equipped
« Last Edit: April 03, 2007, 05:44:34 AM by 318is91 »
Engine Probs...
« Reply #10 on: April 03, 2007, 09:24:04 AM »
hey guys I called AEM yesterday and there is a little turn knob on the back if the gauge.  Its really small and I never even noticed it before they told me.  But you can turn it to make the gauge send a narrowband signal instead of a wideband one.  So I am going to try and put it on if I have time today.  So I am pretty sure I need to send the signal from the gauge to the pin #70 on the ecu?  And I can take power and ground from the o2.
Engine Probs...
« Reply #11 on: April 03, 2007, 10:01:55 PM »
well I got the AEM wired up and working and the car is still pissed.  The old o2 was deff toast but the car isn't idling good at all and it sounds like a wrx.  I haven't had a chance to get on it but the car's AFR's seems to be fine.  At idle the car bounces from like 400-1000rpms but it doesn't cut out.  The vacuum lines are fine.  I'm kinda confused as to what the prob could be.  I'm hoping that I haven't lost a valve or something...
If anyone has any idea's I would really appreciate it as I have to drive 2 hrs  home fri :(
nickmpower
Engine Probs...
« Reply #12 on: April 03, 2007, 10:26:32 PM »
Is this the AEM UGO?
Engine Probs...
« Reply #13 on: April 03, 2007, 11:05:11 PM »
UEGO yup, there is a rotating switch in the back that I moved from the wideband signal p0 to the narrowband signal p4.
nickmpower
Engine Probs...
« Reply #14 on: April 03, 2007, 11:21:35 PM »
hmmm. I didnt know it could do that. Nice
