oK i got the bently manual for the m42 engine and im going to start removing my head within the next few day is there ANYTHING i should be aware of that the book does not tell me? anything anyones learned from trial and error please let me know i want to do it once and do it right
I don't know if this will apply to cars with head bolts, but I had head studs and the damn timing chain would get caught on the guide rails when I would try to lift it off. I ended having to remove the crank pulley (244 ft.lbs), the AC compressor and bracket (PITA!), and then loosen the drivers side rail.
Special ToolsCam locking tool
TDC Pin
Crank pulley holder
Just a tip before you lift the head make sure that you have a pan underneath the engine. When I lifted it coolant and oil came flooding out.
