Author Topic: New Corbeau GTS-II Seat  (Read 7841 times)
Awgy
« on: March 12, 2007, 09:03:27 PM »
Picked up a Corbeau GTS-II driver seat.
Also I found a non-airbag wheel to replace my airbag one
The reason I purchased one seat is cause my driver side was broken and needed to be replaced asap and didnt want a used non sport from a junkyard.
jpod999
« Reply #1 on: March 12, 2007, 10:49:03 PM »
Nice seat.  Me likey.
What did you have to do to replace the steering wheel.  I want to put in an Mtech 1 wheel in my car.
Awgy
« Reply #2 on: March 13, 2007, 09:36:42 PM »
Quote from: jpod999;21160
Thanks,
I just swaped it out and installed the new. It needs a spacer to remove the slight play. That should be easy to fix next time to the wrecking yard.
« Reply #3 on: March 14, 2007, 06:20:43 AM »
The mtech 1 is a nicer wheel than that man!
Better grip points...those came standard on every eta!
shellback
« Reply #4 on: March 14, 2007, 08:26:11 AM »
M-tech I wheel is def nice. I highly recommend it. I couldn't afford a M-tech II!
I used a washer to fix the spacing issue. My only complaint is my knuckles hit the turn signal arms. A slight bending of the arms solves that issue.
Best of luck.
Chris
Awgy
« Reply #5 on: March 14, 2007, 09:55:23 AM »
Yeah, the m-tech is a lot nicer. I found this one for 5 bucks.
I just wanted that airbag gone. If i run across an m-tech i will grab it for sure.
Bunta
« Reply #6 on: March 21, 2007, 07:39:26 PM »
clean that carpet man. and get some floor mats.
Get on it.:D
How do you like those seats? comfortable? well made?
Ive been looking into getting a set of those they look pretty good in an e30.
HUnter
christophbmw
« Reply #7 on: April 14, 2007, 01:46:00 PM »
i almost bought a set of those seats also. i bet they are nicer for the cold Denver weather too, unlike the cold stock vinyl.
how do you like them?
peteM3power
« Reply #8 on: April 15, 2007, 02:56:03 AM »
Nice seat... it looks to be very supportive!
Pete
Stoggs
« Reply #9 on: April 29, 2007, 12:51:43 PM »
Why delete the airbag?
« Reply #10 on: April 29, 2007, 03:26:21 PM »
Quote from: Stoggs;24766
Its about 16 years old.
Do you want a 16 year old bunching bag coming out at you? That thing will do more damage than good.
Thats my opinion.
BTW, how much was that seat?
