Author Topic: Service Interval light batteries  (Read 29762 times)
johna
    • My BMW 3 Series Website
« on: March 29, 2006, 09:08:36 PM »
Most E30 owners have heard about problems with the batteries on the Service Interval (SI) board where batteries have leaked causing instrument problems but fortunately this doesn't effect some of our 318is's.
The problem is caused by the use of rechargable Ni-Cd batteries but of the 318is's I have seen all have used non-rechargable Li (Lithium) batteries which are not prone to leaking like the Ni-Cd's.
However, this means that the Lithium batteries will eventually require replacement as they have a limited lifespan (7 years was suggested but mine have been in there 15+ years). They can be replaced fairly easily if you are a handy with a soldering iron.
You can identify which batteries you have by looking for the words Ni-Cd/Ni-Cad/Nickel-Cadium or Li/Lithium on the batteries themselves.
For those that have Ni-Cd batteries, according to an electronics technician I discussed this with the Ni-Cd's leak because they are often being over-charged.
If you have had battery acid leak on the circuit board for a reasonable amount of time you can probably fix the board by cleaning it with circuit board cleaner and repairing any tracks that have been eaten away by the acid (with bits of wire soldered on to replace missing track), then protecting the circuit board with a circuit board lacquer. And of course you would need to change the Ni-Cd batteries. And you can't swap them for Lithium batteries as they are not rechargable.
« Reply #1 on: March 29, 2006, 09:11:42 PM »
Another option is to solder in leads to a remote battery pack to use the Lithium batteries.  Then, you only have to remove the cluster (for that) one time.  Leave your battery pack more accessible, and when it is time to swap, you can just pull the old ones and stick new ones in there.
Febi Guibo
  • m42 reporter
« Reply #2 on: March 29, 2006, 09:25:02 PM »
The lithium batteries (3 volt, with three prong 'feet') for our boards are available here:
http://www.tselectronic.com/dantona/comp7.html
Can somebody provide a definitive list of everything that goes wrong when your batteries are out?
- service interval lights?
- what else?
Support M42club.com !!
M42boy
« Reply #3 on: April 07, 2006, 09:46:33 PM »
Quote from: Febi Guibo
Thanks for the link.  I have a connection and going to try to get a batch of these for free just for M42Club members.  I'll see what I can do.
shellback
« Reply #4 on: April 08, 2006, 09:10:48 PM »
How do you remove the old batteries from their socket. I mean, these things are jammed in there - is that glue?
Anyway, I realy don't look forward taking that dash apart again! I broke one of the two "A" tabs on the top already!
Febi Guibo
  • m42 reporter
« Reply #5 on: April 09, 2006, 09:47:47 AM »
To remove the batteries, you have to carefully de-solder them. The glue on the top of the batteries is just hot melt glue to keep them from vibrating.
You can get a little suction style 'bulb' at radio shack to help with the desoldering... but basically, just use a soldering iron to heat up the solder where the batteries are mounted to the pcb, and eventually, they will come free.
shellback
« Reply #6 on: April 09, 2006, 12:34:38 PM »
got it - thanks,
Chris
JP 91iS
Thread revival
« Reply #7 on: September 07, 2008, 04:00:13 PM »
Quote from: Febi Guibo;1664
- what else?
I was wondering this myself.  My tach gauge isn't working but when I pulled the cluster I noticed the plug wasn't seated properly, so that may have been the problem.  I want to remove the SI board completely but am worried about losing other functions on my gauge cluster.  Does anyone know what (if anything) else would stop working if I completely removed my SI board?  (I read somewhere that you can do this on some clusters)
edit: I know my batteries are bad since I can't reset the lights by jumping the pins at the diagnostic port.  I'd like to simply remove the hassle of failing/non-functioning lights.  Also does anyone have a link for more info on the remote battery pack?  Sounds like a good option if deleting the board is not possible.
« Last Edit: September 07, 2008, 05:57:13 PM by JP 91iS »
-JP
Project M42: generating funds
JP 91iS
« Reply #8 on: September 07, 2008, 07:02:32 PM »
Quote from: JP 91iS;56222
so looks like no.  I tried it out without the SI board and looks like nothing is working except maybe my fuel gauge.
Anyone with info on the remote battery mod?
Edit: I see that the May '07 issue of Roundel has an article that gives a nice DIY for moving the batteries to a remote location.  So... if anybody has this issue and feels like sharing that article, I would seriously appreciate it.  Or if anybody knows if there is a copy online somewhere.
Roundel Magazine May 20007:
Move 'Em Out! - by BRIAN AFTANAS
A common DIY project for E30 owners involves the rechargeable batteries on the Service Indicator board; they're only a pain the first time.
« Last Edit: September 07, 2008, 08:15:03 PM by JP 91iS »
-JP
JP 91iS
« Reply #9 on: September 07, 2008, 08:54:52 PM »
Maybe I'm going overboard here, but I found this post on bf.c and it is full of information so I thought I'd paste it here:
Quote
djb2
09-18-2006, 07:19 PM
The Service Indicator (SI) board is a circuit board in the instrument
cluster. Its most obvious function is to monitor the engine usage in
order to count down the time until the next recommended oil change or
inspection, reporting using the bar graph on the cluster. A more subtle
function is to read the "code plug" at start up and use this information
to translate fuel injector and ignition pulses to drive the tachometer
and fuel economy meter.
The SI board batteries provide back-up power to retain the service
counter when the main battery is dead or missing. Much like a UPS for
a desktop computer, they are intended to prevent data loss during a
brief power outage rather than to be a long-term power source. Since SI
board batteries are a pain to replace, you should not remove the battery
for storage and avoid leaving the car sit with a dead battery.
There are two major variations of the Service Indicator (SI) board in
the instrument cluster, the original type with NiCad batteries and the
redesigned retrofit board with long-life Lithium batteries.
NiCad boards have two 1.2V 'AA' cells in series. Fresh batteries will
power the SI board for about a month if the main battery is
disconnected, and will slowly recharge when main battery voltage is
restored. The NiCads typically to last for 5 to 15 years.
Lithium boards have two 3V lithium cells in parallel, which will last for
well over a decade of stand-by use. They should power the SI board for
several months if you remove the main battery, but this will permanently
consume part of their life.
The problem with NiCad board, and the reason for the SI board redesign,
is that NiCad cells don't fail gracefully. If you discharge an old cell
to zero volts (really below 0.6V), metal whiskers start growing
internally. These will short out the cell, preventing it from
recharging at all. The original SI board had two design flaws based on
connecting the microprocessor directly to the batteries: it would
discharge the batteries completely trying to preserve the counter state,
and shorted batteries will prevent the microprocessor from working at
all when the power is restored. Even if you don't care about the oil
change suggestion, other functions that depends on the coding plug
(e.g. the tach) will not work.
The Lithium battery board fixed the design problem. It has two
non-rechargeable 3V lithium cells that are diode isolated from each other
and main battery power. Either cell can provide back-up power, with the
load normally shared to provide twice the life. Even if both cells
fail, the main battery can still power the circuitry.
So now that you know how the SI board batteries work and fail, how do we
fix the problem? I'll start with the NiCad board, since people with bad
lithium batteries might not even know that they have have dead batteries.
There are several web pages with excellent instructions and pictures on
removing the SI board. I won't repeat them here, instead only covering
the battery information that isn't obvious from physical disassembly.
The original NiCad batteries are standard size AA cells (Varta 500 RST)
with board-mount tabs welded on the ends. Your options are to buy
replacements with the same board-tab connections from a specialty
battery supplier (hobby shop or on-line), buy cells with solder tabs or
wires attached, or use wire a remote battery holder to the circuit
board.
Whatever mounting option you choose, use *only* standard capacity,
high-temp NiCad cells. "Better" battery chemistry types (NiM-H,
Lithium) or specialized cells (rapid charge, high capacity) cells are
not better for this application. Non-NiCad chemistries will have
different voltages, and high capacity or rapid recharge NiCad cells have
design compromises that reduce longevity. NiM-H batteries are reported to
work, but the continuous trickle charging will destroy them.
A good choice of battery is the Sanyo high-temp standard capacity cells.
If you can't find cells with solder tabs or want to remote-mount the
cells for easier replacement, put them in a holder. Radio Shack has a
nice dual AA cell battery holder, part #270-408. It's fully enclosed
with wire leads already attached, and typically stocked in-store for
about $1.49.
I don't recommend Radio Shack as a NiCad battery source. They will do
in a pinch, but the cells are overpriced and not the best type for this
application.
Now on to the lithium battery SI board. This is much more academic,
since these board generally don't have problems. However our cars are
getting old, so some of these boards may start needing battery
replacements at some point.
Lithium Battery info
The newer style SI board uses a MnhO2 Lithium battery by Sanyo (CR1425OSE).
The board on my 1987 325is is dated 13.94, and numbered 992 647 196.
It clearly is a replacement, likely installed after only seven years.
The batteries on my board are dated 93-08, and measure 3.17V in 2004.
Nominal end-of-life voltage is 2.0V, but at 2.5V little capacity remains.
The two 3V cells are connected in parallel but isolated by diodes.
Either cell can fail individually and the board will still work.
The cells have an extra isolation film under the conformal coating,
presumably to protect the board from overheating or leakage.
More details about the battery:
Sanyo CR14250SE 3V 850mAh 14.5x25mm (1/2 AA size) lithium cell.
The 14250 is a standard primary (non-rechargeable) Lithium type, available
from multiple sources.
sanyo.wslogic.com/pdf/pdfs/CR14250SE.pdf
The 'SE' variant was optimized for high capacity and long shelf life.
Other variants are optimized for high discharge rate or light weight.
The standard 'SE' discharge rate is 0.5 mA.
This is ten times less than the power needed to light a small LED.
At the standard rate the cells will discharge in 72 days.
At a 10uA rate the cells will last 10 years.
The temp range is -40C to +85C, rather than -20C+60C of other brands.
The cell may weigh up to 11g, rather than as little as 7g.
The Sanyo 'SET-FT' suffix indicates welded tabs for board mounting.
Modern cells are available in 950mAh versions, but long shelf life and
seal life are more important than capacity.
Now I'm curious about a few things:
1) My cluster is a VDO but has a motometer SI board, is that normal?
2) Since we have the newer boards with Lithium batteries, shouldn't the service lights still work by running of the cars main battery after the SI batteries fail?
I've decided that since these batteries last much longer than the rechargeable ones, its not really necessary to install a remote battery pack.  Plus I had no idea how to make one (do I have to use the same style Lithium batteries? do they have to be wired in parallel and isolated by a diode?)  I would be interested in know how it is done though.
-JP
« Reply #10 on: September 07, 2008, 10:30:55 PM »
Another option is to just remove the whole board with the LEDs and be done with it. Its not like any of us go by its recommendation to service the car anyway.
JP 91iS
« Reply #11 on: September 07, 2008, 10:33:45 PM »
Quote from: tjts1;56247
This is what I was asking about in post #8.  Have you done this?  I pulled the board and reinstalled the cluster and it didn't look like anything was working.
-JP
« Reply #12 on: September 08, 2008, 12:50:46 AM »
Theres 2 circuit boards. A large one that houses the batteries. I kept that one in place. Then theres a smaller circuit board that houses the LEDs. I just removed the smaller one with the LEDs. Kept the large on in place.
I've had it out for 6 months now and everything still works fine.
« Last Edit: September 08, 2008, 12:57:51 AM by tjts1 »
JP 91iS
« Reply #13 on: September 08, 2008, 10:49:31 AM »
Quote from: tjts1;56265
Cool.  So were your batteries still good?
-JP
« Reply #14 on: September 08, 2008, 11:07:50 AM »
Quote from: JP 91iS;56307
Nah, batteries are toast. I left them in there anyway.
