Author Topic: I need motor mounts  (Read 8964 times)
dino245
I need motor mounts
« on: March 29, 2006, 02:18:43 PM »
I installed my new header and found out that the pass side mount is torn completly apart. I would like to install solid rubber mounts but I dont have a cross refrence to another model that I can use. Is it possible to use M20 solid rubber mounts? Any help would be appreciated.
2002maniac
I need motor mounts
« Reply #1 on: March 29, 2006, 03:46:56 PM »
I believe e28 535i mounts are what you need.
How's the header?
dino245
I need motor mounts
« Reply #2 on: March 29, 2006, 03:58:31 PM »
header works fine but I think I need a larger throttle body now. the car pulls nicely and sounds alittle louder.
I need motor mounts
« Reply #3 on: March 29, 2006, 06:59:07 PM »
e28 mounts are definitely a cheaper route. Expect some added in cabin noise and vibration.
christophbmw
I need motor mounts
« Reply #4 on: March 29, 2006, 07:45:53 PM »
Quote from: Eurospec
damn i wish i knew this before i spent $90 a pair for new ones.:(
I need motor mounts
« Reply #5 on: March 29, 2006, 08:56:23 PM »
Yeah, the E28 535i ones are it.  I have used them in both cars.  Throttle response benefits greatly.  A bit more noise & vibration, but it is well worth it.  You just have to grind off the alignment tabs.
johna
    • My BMW 3 Series Website
I need motor mounts
« Reply #6 on: March 29, 2006, 09:26:43 PM »
Apparently the engine mounts from M30-powered E28 535i will fit with minor modifications. Part number is 11811132793 and you may also need some 2mm washers with a 10mm internal diameter. The E28 mounts need to be modified by cutting off the alignment tab.
Pedro
    • http://www.realoem.com/bmw
I need motor mounts
« Reply #7 on: March 29, 2006, 10:37:20 PM »
I went to IE on a sat and picked up a pair of poly eurathane mounts for $80. Engine still isnt in the car yet so i cant tell you what they feel like.
m42technic
I need motor mounts
« Reply #8 on: March 29, 2006, 10:53:20 PM »
Quote from: Pedro
IE doesnt make M42 mounts IIRC?
m42technic
I need motor mounts
« Reply #10 on: March 29, 2006, 11:42:25 PM »
Well whadda know.  Shows how much I keep up with their product line.  :)
I need motor mounts
« Reply #11 on: March 30, 2006, 01:05:38 AM »
Wasn't aware IE had M42 mounts. Good to know, thanks.
kowalski
  • El\' Duder
I need motor mounts
« Reply #12 on: March 30, 2006, 03:22:44 AM »
i duno if this was mentioned yet but the e21 engine mounts work, and theryre less then 50-100$ (the 5 serries ones i believe) call patric and BMA, he'll hook you up.
Sale:
Fore Sale Thread
I need motor mounts
« Reply #13 on: March 30, 2006, 12:05:02 PM »
Quote from: kowalski
Does the thread need to be modified? How do they compare to stock?
I need motor mounts
« Reply #14 on: March 30, 2006, 12:39:51 PM »
When I last bought my M30 mounts they were $33 per side.  Got them from http://www.pelicanparts.com .  BMA is cool & alll, but I much prefer Pelican.  Fast shipping, complete online catalog (you can punch in any PN and itll get you a price).
