Author Topic: I need help wiring my elips  (Read 2945 times)
kramerica5000
« on: February 24, 2007, 11:20:55 AM »
I got some Bosch elips for my car. I couldn't find pigtail connectors so I had to rig something up . . . anyone know where I can get pigtail connectors for the Bosh lamps? Are they the same as the Hellas?
Also . . . I'm trying to work out how to get back to having all 4 lights on when switched on high. I have a relay in now that closes when the highs are turned on to backfeed power from the high beams to the low beams. Problem is I am using the power from the high beams to throw the relay AND power the low beams . . . so once the its turned on it creates a closed loop and  i can't switch back to just lows without cutting off  the lights altogether.
That probably makes no sense . . . but has anyone figured out how to do this?
:confused:
kramerica5000
« Reply #1 on: February 24, 2007, 12:03:03 PM »
OK I think I figured out how to do the wiring by sodering the relays together in the fuse box.
I even found part #s for the connectors, but I can't find anywhere online that sells them. Does anyone know where to find them?
Febi Guibo
  • m42 reporter
« Reply #2 on: February 24, 2007, 01:23:01 PM »
Patrick at bmaparts or Vaheh at crevierbmw.com can get you the euro bosch wiring pigtails and plastic plug 'retainers'... They are bmw items.
Support M42club.com !!
kramerica5000
« Reply #3 on: February 24, 2007, 05:28:43 PM »
Quote from: Febi Guibo;20077
Thanks man. I was able to find the parts in the online catalog at crevierbmw. I'm over an hour away from the nearest dealer, so its a PITA when I can't find stuff online. I've got those places bookmarked now.
Eric
