Author Topic: to skin a cat (m20 flywheel swap)  (Read 17598 times)
rob_e30
« Reply #30 on: March 06, 2007, 04:26:49 PM »
Well I'm using a complete M20 starter, as pictured here...
nickmpower
« Reply #31 on: March 06, 2007, 06:26:20 PM »
he is mine
nickmpower
« Reply #32 on: March 06, 2007, 06:31:01 PM »
looks like the m20 one will work fine, though its hard to tell exacly as their end cases are different. You might want to to take the motor of the starter off so you can spin the gears then set the starter in the bellhousing and spin it to make sure they dont touch, thats what im going to do.
let us know when you get it bolted up
« Last Edit: March 06, 2007, 06:44:59 PM by nickmpower »
2002maniac
« Reply #33 on: March 06, 2007, 07:49:44 PM »
update.
Well, this isnt going to be as easy as I thought.  The ID of the gears is different and I'll have to turn down the OD of the flywheel to get it to work.
It will probably be easiest for most to just use the M20 pinion gear.
romkasponka
« Reply #34 on: March 07, 2007, 04:23:57 AM »
Is it posible to fit stock starter motor if m20 flywheel gear was replaced by M42?
E30 318is M42
E36 318is M44
romkasponka
OT
« Reply #35 on: March 07, 2007, 06:57:41 AM »
E30 318is M42
E36 318is M44
steve321
« Reply #36 on: March 07, 2007, 12:56:09 PM »
what sort of weight is the M20 wheel then? i have an M40 flywheel to go into my 318is, but i have turned alot off or it, so mine weighs about 7.3kgs, i believe the M40 is a straight swap for the M42, but i hav'nt got mine fitted just yet.
steve
________
MERCEDES-BENZ M275 ENGINE
« Last Edit: April 26, 2011, 12:38:52 AM by steve321 »
steve321
« Reply #37 on: March 07, 2007, 12:58:51 PM »
standard M40
my M40 one
steve
________
Infants wellbutrin
« Last Edit: April 26, 2011, 12:39:06 AM by steve321 »
johna
    • My BMW 3 Series Website
« Reply #38 on: March 07, 2007, 04:58:55 PM »
M40 flywheel was simple replacement for me. Used shorter M40 flywheel bolts and M40 clutch kit. Wish I had reduced weight like you have though as the flywheel didn't make much difference.
Jimmy Lewis
« Reply #39 on: March 07, 2007, 09:01:30 PM »
If anyone else attempts this and finishes before 2002maniac please share the results. This seems much less of a headache than trying to deal with modifying the starter as seen in m42boy's thread. Good deal.
1999 Estoril M3
1991 Brilliantrot 318iS
(for sale)
Jimmy Lewis
« Reply #40 on: March 07, 2007, 09:02:02 PM »
If anyone else attempts this and finishes before 2002maniac please share the results. This seems much less of a headache than trying to deal with modifying the starter as seen in m42boy's thread. Good deal. :cool:
« Last Edit: March 07, 2007, 09:03:29 PM by Jimmy Lewis »
1999 Estoril M3
(for sale)
romkasponka
E30 318is M42
E36 318is M44
romkasponka
« Reply #42 on: March 15, 2007, 11:48:03 AM »
don't know weight yet..
E30 318is M42
E36 318is M44
steve321
« Reply #43 on: March 15, 2007, 02:30:50 PM »
whats that one, an M20 one? looks like it would be well light
steve
________
Does cocaine help you study
« Last Edit: April 26, 2011, 12:41:29 AM by steve321 »
romkasponka
« Reply #44 on: March 15, 2007, 03:25:34 PM »
Yes, it's m20 flywheel, but slightly lightened.. :)
« Last Edit: March 15, 2007, 03:37:00 PM by romkasponka »
E30 318is M42
E36 318is M44
