Author Topic: to skin a cat (m20 flywheel swap)  (Read 17618 times)
Bunta
« Reply #15 on: March 01, 2007, 08:15:14 PM »
so if you need change the toothed rings or the starter gear, use m20 clutch/flywheel(lightened) and 323tob your made in the shade?
franz
« Reply #16 on: March 01, 2007, 10:54:52 PM »
this is the first time hearing this
what do you gain by chaning the flywheel to a m20
lighter flywheel is good
but by how much lighter and what is the cost lightening a flywheel
2002maniac
« Reply #17 on: March 01, 2007, 11:17:18 PM »
Quote from: franz;20400
the stock M42 dualmass flywheel is 27lbs
The M20 flywheel can be taken down to 12-15lbs
I dont know about the cost as I'm doing mine myself.  I would expect it to be under $50
nickmpower
« Reply #18 on: March 02, 2007, 12:55:05 AM »
when is this going to be running? let me know if you figure out a starter to use. Mine hits the flywheel a tad since im not using the spacer, but i think an m2 one might work. I wont be home for a month so if you figure out something let me know.
romkasponka
« Reply #19 on: March 02, 2007, 03:27:12 AM »
Quote from: 2002maniac;20403
Will you balance it by your self?
E30 318is M42
E36 318is M44
2002maniac
« Reply #20 on: March 02, 2007, 10:40:14 AM »
Quote from: nickmpower;20413
stock starter should work with the 42 gear on there.  You can see in my sketch that the location of the gear on the flywheel is the same (1mm difference)
2002maniac
« Reply #21 on: March 02, 2007, 10:41:50 AM »
Quote from: romkasponka;20415
no, the machine shop that bored my block is going to balance the bottom end with the flywheel and pressure plate installed.
nick,
  it wont be running until my motor is built.  mid-summer probably.
black318i
« Reply #22 on: March 04, 2007, 01:05:46 PM »
Anyone know how much HP a stock m20 Clutch is good for?
romkasponka
« Reply #23 on: March 04, 2007, 02:17:51 PM »
Quote from: black318i;20527
there was no problem with 240hp , sachs 325ix kit....
« Last Edit: March 04, 2007, 03:18:32 PM by romkasponka »
E30 318is M42
E36 318is M44
nickmpower
« Reply #24 on: March 04, 2007, 03:09:27 PM »
Quote from: 2002maniac;20421
o yeah. The problem i have is that the m20 gear is longer then the m42 gear
« Reply #25 on: March 04, 2007, 08:23:15 PM »
So:
1) Swap M42 ring onto M20 flywheel
2) Machine .23 to .35 from engine side of M20 flywheel
3) Balance flywheel
Anybody know how closely it needs to be balanced? Could you do a cleanup pass on the lathe and accomplish the balancing?
What 323i TOB is required.
« Last Edit: March 04, 2007, 08:26:12 PM by D. Clay »
rob_e30
« Reply #26 on: March 05, 2007, 08:19:28 PM »
Quote from: 2002maniac;20381
I also discovered that if you have the flywheel lightened on the engine side, you dont need to space out the M20 flywheel as described in a few of the writeups.
Yep, this works and boy was I pleasantly surprised (I had not seen this thread yet)!  M20 flywheel is down to about 12.5lbs and I'm using an M20 starter along with the transmission that was in the car (from a 325i) so no other changes.
nickmpower
« Reply #27 on: March 05, 2007, 11:00:15 PM »
Quote from: rob_e30;20640
so is the starter bolted up and you know the pinion doesnt touch the flywheel? if so, sweet
rob_e30
« Reply #28 on: March 06, 2007, 08:42:36 AM »
Quote from: nickmpower;20660
I was unaware that this was a concern.  I don't recall seeing this as an issue in the threads I read, but I certainly could have missed something.  I thought that the M20 flywheel and M20 starter could be transfered as a set?  I've not bolted up the tranny yet but expect to this week.
Any additional insight is appreciated.
nickmpower
« Reply #29 on: March 06, 2007, 12:53:52 PM »
well i didnt need to use a spacer with my jb racing flywheel and my m42 starter with m20 pinion hits the flywheel, as the m20 pinion is longer then the m42 pinion. it needs about 1mm more room. if you could tkae a pic of your starter i could probably tell you if it will wok
