Author Topic: bilstein TC (touring class)  (Read 4919 times)
RED IS 91
« on: February 18, 2007, 09:22:04 AM »
Do these require adding oil to the strut housing ?
RP Kennedy
« Reply #1 on: February 18, 2007, 02:43:18 PM »
I believe D. Clay has those shocks.  He'll give you first-hand knowledge.
cecotto
    • http://www.cecotto.dk
« Reply #2 on: February 18, 2007, 03:10:10 PM »
Quote from: RED IS 91;19704
I cant remember where i read this, and just looked for it again without luck..
If it's an Bilstein Upside down construction it's my understanding that it's recomended against adding oil to the strut housing, as the shock seals are contained inside the strut, and the oil could damage the rubber in those seals.
The upsidedown construction can be considered like an ordinary shock except that it's the bottom that sticks out , usually this is very thick to acomodate the valving. And the strut is sealed with a large screw with a rubberseal.
In other words, the piston is fixed inside the strut, and the cylinder is what moves in relation to the piston.
Where on a standard design its the other way around.
Hope to help..
Steffen Otto Jensen
E30 318is
E30 M3
« Reply #3 on: February 18, 2007, 04:54:27 PM »
My struts were oil coated on the inside but I didn't add any oil. I did put anti-sieze on the collar nuts.
RED IS 91
« Reply #4 on: February 18, 2007, 05:33:29 PM »
Quote from: D. Clay;19716
did you dump the old oil out of the strut housing ???
« Reply #5 on: February 18, 2007, 09:14:31 PM »
Yep. Just poured it out but left the insides coated.
M42Iberia
« Reply #6 on: February 20, 2007, 08:29:27 PM »
i've read that three to four oz. are supposed to be added...i believe that it was in the benyley's
Noel Higa
« Reply #7 on: February 20, 2007, 11:47:48 PM »
This exact same discussion just reached a pretty inconclusive conclusion (?) on Bimmerforums:
http://forums.bimmerforums.com/forum/showthread.php?t=692761
The right answer seems to be...ask Bilstein and let us know what you find out.
RED IS 91
« Reply #8 on: February 21, 2007, 06:40:19 AM »
Quote from: Noel Higa;19852
Unfortunately I can't get ahold of Bilstein ,at least I haven't found a way to contact them. I have emailed Turner Motor Sport and asked them since they are a distributer of Bilstein.It seemed like a easy question.:confused:
I'll keep you posted .
jajou318
« Reply #9 on: February 21, 2007, 08:55:34 AM »
somewhat of a teaser...
RED IS 91
« Reply #10 on: February 21, 2007, 01:30:55 PM »
I had to go to yellow book .com to get a number for bilstein in california.
I spoke to the installation guru and he said no oil required for the touring struts.
Alrighty Then
Case Closed
Thanks for everyones input.
Noel Higa
« Reply #11 on: February 22, 2007, 07:42:30 AM »
He came up with the same answer on Bimmerforums:  "I got ahold of Patrick at bav auto and he said No Oil Required with the touring struts.  Thanks everyone"
