Oil found in spark plug #3
Author Topic: Oil found in spark plug #3  (Read 3335 times)
Minkee
« on: March 29, 2006, 03:26:10 AM »
So I found about a 1/8 of a teaspoon of oil in cylinder #3's spark plug.  Do you guys just think its the gasket?
Whats the worst that it could be? Should I just replace the valve cover gasket and see what happens?
I just noticed this while replacing the plugs today.  I'm sure the last owner drove on it like this for a few months too.  Whats the worst to expect.  :(
kowalski
  • El\' Duder
« Reply #1 on: March 29, 2006, 11:05:49 AM »
Edit: valve cover gasket
« Last Edit: March 29, 2006, 12:10:08 PM by kowalski »
Sale:
Fore Sale Thread
nickmpower
« Reply #2 on: March 29, 2006, 11:59:06 AM »
I dont know how that could be the pan gasket.
I think you are trying to say that there was oil in the cylinder head reccesed area for the spark plug. It is probably just the VC gasket. I think i have an extra one with the 4 small inner parts if you need one
kowalski
  • El\' Duder
« Reply #3 on: March 29, 2006, 12:09:53 PM »
hahaha oops i meant to say valve cover gasket:) sorry
Sale:
Fore Sale Thread
Tonyb
« Reply #4 on: June 11, 2006, 09:46:15 PM »
Make sure the Valve cover bolts are tight, mine where loose.
« Reply #5 on: June 12, 2006, 11:48:33 AM »
mine was missing a bolt in #3.  So that let a lot of oil in.  Check that out.
« Reply #6 on: June 12, 2006, 02:19:19 PM »
Valve cover gasket for sure.  I am having a big leaking problem as well.  The rubbe gets hard as it ages, working less & less well.  Replace them, Lord knows I need to.
2002maniac
« Reply #7 on: June 12, 2006, 07:43:25 PM »
Quote from: Tonyb
not too tight!  They strip very easily
///Motorsport
« Reply #8 on: June 16, 2006, 04:28:46 PM »
when i got mine two were loose, a tech gave them steel sleeves, now another is loose.  should i now check for some serious issues, or spark plug oil as well?
