Brake Upgrade
Author Topic: Brake Upgrade  (Read 12430 times)
romkasponka
Brake Upgrade
« on: February 13, 2007, 05:36:49 AM »
What do you think?
With ~300mm disc..
« Last Edit: February 13, 2007, 07:05:06 AM by romkasponka »
E30 318is M42
E36 318is M44
Gunni
Brake Upgrade
« Reply #1 on: February 13, 2007, 07:21:41 AM »
what caliper is that?
romkasponka
Brake Upgrade
« Reply #2 on: February 13, 2007, 07:23:55 AM »
E38 6 cil engine only
E30 318is M42
E36 318is M44
Gunni
Brake Upgrade
« Reply #3 on: February 13, 2007, 10:15:08 AM »
if you can fab up a adapter strong enough then no problemo,
not sure it will cleare that wheel and run 300mm´s
Alpine003
Brake Upgrade
« Reply #4 on: February 13, 2007, 10:21:22 AM »
I guess if you want to stick with BMW, but have you looked into the 300zx tt aluminum calipers? Nice, strong and light saving on unsprung mass. I had a set awhile ago but really contemplating on getting some used ones again to see how the measurements would line up.
romkasponka
Brake Upgrade
« Reply #5 on: February 13, 2007, 10:38:58 AM »
these are brembo 3,2kg, ferodo DS3000 racing pads available ;)
E30 318is M42
E36 318is M44
christophbmw
Brake Upgrade
« Reply #6 on: February 14, 2007, 09:35:20 AM »
Quote from: Alpine003;19437
ya, if you use the BMW calipers your unprung weight would increase. do they nake adapters for the nissan calipers for our cars?
jajou318
Brake Upgrade
« Reply #7 on: February 14, 2007, 09:42:57 AM »
Quote from: christophbmw;19528
nope. everything about that would have to be custom made.
somewhat of a teaser...
romkasponka
Brake Upgrade
« Reply #8 on: February 14, 2007, 09:50:23 AM »
but the price for these was 2x25$ ;)
E30 318is M42
E36 318is M44
dino245
Brake Upgrade
« Reply #9 on: February 14, 2007, 10:34:57 AM »
I tried using these calipers already. too large and cumbersome that is why I did the dynalite calipers and they fit in 15" wheels. I figured no matter what the price of the calipers, if they dont work right who cares.
romkasponka
Brake Upgrade
« Reply #10 on: February 14, 2007, 10:58:42 AM »
Quote from: dino245;19538
I'l try to fit them in 15" wheel, will see...
What do you mean by saying they dont work right?
E30 318is M42
E36 318is M44
dino245
Brake Upgrade
« Reply #11 on: February 14, 2007, 11:49:42 AM »
What is the piston diameter. Compare this to the factory piston and then compare the increase in caliper piston area and the master cyl. piston area. I would guess that the calipers have pistons that are way bigger than what the stock master can move. I looked into these brembo calipers but the bodies and the pistons are way too large and for mee look out of proportion to the car. It would be like putting a big block chevy in a chevy sprint. This is just my opinion.
romkasponka
Brake Upgrade
« Reply #12 on: February 14, 2007, 12:44:31 PM »
The guys in Russia just swaped and they say it works fine. I have few xls calculators for brakes and will try to make some calculations..
« Last Edit: February 14, 2007, 12:48:06 PM by romkasponka »
E30 318is M42
E36 318is M44
romkasponka
Brake Upgrade
« Reply #13 on: February 19, 2007, 02:37:52 PM »
Audi A3 brake disc 288x25m
E30 318is M42
E36 318is M44
romkasponka
Brake Upgrade
« Reply #14 on: February 21, 2007, 09:56:59 AM »
E30 318is M42
E36 318is M44
