M20 flywheel conversion
Author Topic: M20 flywheel conversion  (Read 12668 times)
gundy318
« on: February 12, 2007, 07:58:14 PM »
I've bought a m20 flywheel that i had resurfaced and a 325i clutch kit that comes with a T/O bearing. Can i use that T/O bearing or do i need the one from the 323?
« Reply #1 on: February 13, 2007, 01:41:29 AM »
you will need the 323 tob
gundy318
« Reply #2 on: February 13, 2007, 09:00:02 AM »
alright thanks
Vladi
    • http://www.bmwzone.ro/forum
« Reply #3 on: February 28, 2007, 04:36:39 PM »
I used my M40 TOB and it works. :confused:
Tob
« Reply #4 on: February 28, 2007, 07:12:52 PM »
Quote from: Vladi;20310
In realoem.com, the part numbers are the same for an E30 318is and and a 323i. From that it appears that the 1991 E30 318is TOB should work with the M20 Flywheel and clutch.
nickmpower
« Reply #5 on: February 28, 2007, 10:03:48 PM »
noooo
« Reply #6 on: March 01, 2007, 09:55:21 PM »
What is the part number of the TOB for M20 flywheel and clutch swap?
realoem shows
21517521471
as the part number
for 90-91 318is, 323i, anfd the Euro M40.
2002maniac
« Reply #7 on: March 01, 2007, 10:42:29 PM »
seems like the M20 flywheel swap can be alot simpler than we all though!  I'm stoked!
2002maniac
« Reply #8 on: March 01, 2007, 10:51:42 PM »
Quote from: D. Clay;20395
realoem shows
21517521471
as the part number
no, I just checked realoem and it's the e21 323i TOB we need (or do we?)
21511204525
The one you found is for the e30 323. it is also the same as the e30 325i and many others.
nobrakese36
« Reply #9 on: March 22, 2007, 09:28:44 AM »
The clutch we use is out of the 325I not the 325e right?
« Reply #10 on: March 24, 2007, 07:25:09 AM »
its out of the 325i/is
edit:
yes, it is the E21 part that is needed
stuartgallafant
« Reply #11 on: March 24, 2007, 09:52:20 AM »
i have this mod to do on my iS too. why do you need the E21 323i T/O bearing? will the M20 one not work? i was under the impression that all M20 clutches and release bearings were the same
odbod
« Reply #12 on: May 03, 2007, 10:35:47 AM »
I have just put my engine and gearbox together using an lightened M20 Flywheel, 325 Clucth, 323 TO Bearing (which is actually used on 320's as well, but the dealer told me it was only on really early cars) and the engine has gone in to the car today, can't wait to get it running it's only done 37K Miles!:)
I have piccies comparing the IS, 325 and 323 T/O bearings if someone can host them I will post them up, they are quite different, you can see why you need the 323 bearing as it's quite a lot longer and the tabs are in different places.
m44power
« Reply #13 on: May 03, 2007, 12:25:47 PM »
i used my TOB e36 318is too it works great
kramerica5000
question about pressure plate bolts
« Reply #14 on: May 03, 2007, 12:33:49 PM »
Does anyone know if you can re-use the bolts from the m42 assembly to attach the M20 pressure plate to the M20 flywheel?
