Help Car wont start unless cps sensor removed.
Author Topic: Help Car wont start unless cps sensor removed.  (Read 2622 times)
Ibrahim
« on: October 14, 2022, 06:48:55 PM »
Hi, I have a 1994 318i automatic that doesn’t start unless I unplug the camshaft position sensor. I thought the sensor was faulty so I replaced it with a new oem sensor. I still have the same problem. Then I thought the DME might be faulty so I also replaced it from one I bought online. Still the same problem. The camshaft sensor connector pins has  continuity with their respective DME pins (16 and 44).I’m stumped and I dont know what to do. Does anybody have an idea for why the car only start without the cps sensor.
Re: Help Car wont start unless cps sensor removed.
« Reply #1 on: November 12, 2022, 09:12:53 PM »
I moved the topic, you should get a little more visibility here.
Test the sensor resistance between pins 1&2. You should see about 640 ohms. I'd also test the other pairs, you should see very high resistance between them. If the CPS doesn't send a signal to the DME, the fuel pumps are shut off as a safety measure. I'd think that's what's happening in your case.
