Author Topic: Caliper bleed nipple  (Read 3342 times)
mikesjo
« on: February 09, 2007, 08:26:33 PM »
So I got the brakes flushed today at a shop, and they bled everything except the driver side front caliper because the bleed nipple/screw thing was basically seized/rusted. They said they could try drilling it out and putting a new screw in but I don't want them to try and not be able to do it. I guess a new caliper is the best solution?
Opinions, comments?
Finally installed my IE subframe bushings and m3 CABs, car doesn't rattle as much now :).
AL GReeNeRy
« Reply #1 on: February 11, 2007, 04:55:07 AM »
how much extra is all that drilling going to be? youre better off grabbing a new/used caliper if theyre maken you pay extra
if the bleeder screw is rusted up, that means more could be messed up like the caliper piston or brake line.. double check
1991 318is : brilliantrot
kowalski
  • El\' Duder
« Reply #2 on: February 11, 2007, 05:50:16 AM »
they don't know how to use an easy out?
Sale:
Fore Sale Thread
christophbmw
« Reply #3 on: February 11, 2007, 11:02:24 AM »
calipers should be replaced in pairs, so keep that in mind when deciding which route to take.
Nick_318is
  • -Receive: 11
« Reply #4 on: February 11, 2007, 01:33:48 PM »
You can get some rebuilt calipers for a pretty reasonable price. Check at pelicanparts.
romkasponka
« Reply #5 on: February 13, 2007, 03:30:02 AM »
You can weld bolt to nipple and when it is hot unscrew it. It works!
E30 318is M42
E36 318is M44
