Author Topic: Replacing plugs, wires, advice?  (Read 6804 times)
///Motorsport
« on: February 08, 2007, 11:11:24 AM »
Okay so I have a few questions.  Went to my mechanic last night and we figured out (well I had assumed, and he let me know what up) I need new ignition wires and spark plugs.  I also need a chain tensioner, tie-rod assemblies and Lower control arm bushing.
So- I'm going e30 M3 solid rubber offset bushing and new tie rods, tensioner.
What about wires?
I would go OEM Bosch Wires but they could be steep.  What about BavAuto 'high performance ignition wires'?  They also have ignition coils that are 200$, are these worth it? (About the same price as the Boschs I thought?)
I'm not going for gains on these (unless the coils provide somethign I'm missing?) so I'd probably go the cheapest route that gives me oem or better parts.
What plugs?  I've heard there are some good and bad Boshcs for our engines, and notice lots of people like NGK.
I have only a DINAN chip now, but I plan on getting my engine up to spec and adjusting cams 6 degrees (or whatever is typically done and works safe) and going Megasquirt, LWFW and maybe methanol down the road, hopefully early summer.
Then a few months of work and gt28 time.
So what plugs and wires?
RED IS 91
« Reply #1 on: February 08, 2007, 11:24:20 AM »
everyone says NGK for plugs but I've got champs in mine .
Good inexpensive wires (magnecor)
http://www.ultrarev.com/manufacturers.php?manufacturerid=30
« Reply #2 on: February 08, 2007, 01:29:00 PM »
I would check the Coil-on-Plug conversion.
4 coils from Turner Motorsport for $100 plus $50 for conversion kit. Here's all you need to check it out.
http://www.turnermotorsport.com/html/detail.asp?PRODUCT_ID=2310
http://www.m42club.com/forums/showthread.php?t=1682
sheepdog
  • Site Admin
« Reply #3 on: February 08, 2007, 01:44:11 PM »
Quote from: D. Clay;19103
I will second this idea.
Cheaper, and better.
///Motorsport
« Reply #4 on: February 08, 2007, 02:23:08 PM »
Thanks guys, just the advice I was looking for. I will investigate.
mikesjo
« Reply #5 on: February 08, 2007, 02:29:34 PM »
My vote is OEM spark plugs. Bosch Supers F7LDCR. For the wires, look into the magnecor ones. Great alternative to OEM and I believe they're about $70 USD.
///Motorsport
« Reply #6 on: February 08, 2007, 03:17:37 PM »
I think Im going with the COP conversion, who has all these brackets?
So with this bracket and 4 coils from TMS, am i all set?
What Spark plugs? those Bosch Supers are ike 6 bucks each doesn't seem bad.. Anybody object?
AL GReeNeRy
« Reply #7 on: February 08, 2007, 06:31:16 PM »
Quote from: ///Motorsport;19119
the bracket is for sale in the GB section.  you gotta wait in line.  and yes, 4 coils from TMS.
if you decide to get wires, go with oem. but if moneys tight i guess magnecor...
as for spark plugs.  just get the oem NGKs.  bosch super duper bullshit aint gunna do nothin for ya cept waste your money. and yes, NGKs were oem in our cars.
1991 318is : brilliantrot
« Reply #8 on: February 08, 2007, 08:12:27 PM »
magnecor wires are great...i dont see why they would "cheap" alternative...there is certainly nothing cheap about the quality of the wires.
I will be putting a 8.5mm set up for sale soon, once i get pics.
Oh and get yourself a set NGK's!
Alpine003
« Reply #9 on: February 09, 2007, 10:35:29 AM »
Quote from: ///Motorsport;19093
I have OEM wires that check out good and doesn't arc or anything from my replacement motor. $45 shipped(I'll even include some Bosch 4 electrode plugs)
AL GReeNeRy
« Reply #10 on: February 10, 2007, 01:06:48 AM »
sorry to knock your hustle alpine, but i repeat.. STAY AWAY FROM BOSCH SPARK PLUGS!!!
especialy the platinums.. 90% of bosch spark plug failures are from platinums
Alpine003
« Reply #11 on: February 10, 2007, 12:26:21 PM »
Quote from: AL GReeNeRy;19219
No offense taken. I have noticed better running on NGK's than Bosches too. But I can't clearly say that it will make a difference in every car though.
« Reply #12 on: February 10, 2007, 02:09:03 PM »
I second, or third, or fourth or whatever it is...that Bosch Platinum plugs are ass.  I used them ONCE and ever did again.  Using some Bosch Super's or the stock NGK ones are the way to go.
christophbmw
« Reply #13 on: February 11, 2007, 11:07:26 AM »
Quote from: bmwman91;19239
damn ive been running bosch, what model NGK's are you guys running?
RED IS 91
« Reply #14 on: February 11, 2007, 11:35:30 AM »
I believe you'll need
NGK   BKR6EK
