Author Topic: E36 318is with 318is rear brakes and e46 330i brakes, will it work?  (Read 2709 times)
JackMtech
Hey all, so i have a 1994 e36 318is manual coupe (with the rare Mtechnic package), and plan on building a stroked supercharged m42. But im doing all the other things first clutch, flywheel, suspension overhaul, brakes ect.
What im wondering is that im aware that e46 330i brakes are a great swap for the e36. Although I know it might be more of a hassle for me (from what ive read anyway) to swap the rear brakes on my 318is because of the handbrake boot. Will 330i fronts and 318is rears be fine? I plan on slotted rotors for front and rear nonetheless with nice brake pads. At the moment i have brembo pads in there. For my build im aiming for 300rwhp minimum. I should mention that the car is being built for the track, although not very often. Thanks!
-Jack
Freak
Re: E36 318is with 318is rear brakes and e46 330i brakes, will it work?
« Reply #1 on: July 26, 2023, 10:47:50 AM »
You can also swap e46 325i and 328i rear brakes. Discs are 294mmx19mm and hand brake is same like e36.
