Hi guys, got my car out a few weeks ago and on the first drive I got a couple check engine lights at steady state throttle, as soon as I accelerated/decelerated it turned off and the car was driving fine. I came home, stomp tested: 1215, so I figure its some sort of vacuum/intake leak. Next time I drive it the car starts with a check engine light, it's on all the time and now the stomp test won't work and the car is idling poorly.
Reading on the stomp test not working it seems it could be a TPS, but I put a new one on today, still no stomp test and steady check engine light. Also installed new ICV, checked all vacuum lines, and tried a different AFM along side mine after getting it back from Bavarian Restoration. I'm stumped. How can I get the code(s), what else can it be, should I try one of my other ECUs?
