Heyy!, since i already have this thread i didnt want to do a new one, I am making progress on the "conversion" but it took so long to get the thing I needed from ebay
I am now working on it and will keep this thread updated, but I have run into a super mysterious problem that I need to fix.
For some reason, only taking the intake manifold out, (and unplugging the 2 temperature wires and the oil one) and putting it back together made my temp gauge not work anymore.
Here are all the thing I have tested
For context (and after some research) "gauge temp sensor" is the one more in the middle, that only has 1 pin/wire.
-There is a 12v signal on the tip of the connector for the gauge temp sensor
-I assume the ECU temp sensor works fine since the car starts cold without an issue
-Gauge temp sensor is fine (tested it)
-Gauge itself is fine (mounted in another car and worked well)
-If I unplug the battery, wait a few minutes and put it back, the gauge reads full MAX, and keeps there, but if I start the car, after about 30 seconds it starts falling to COLD and after about 5 second its on full COLD and from there, it will never move again, even if I turn of the car and wait a day, the next day it will be on full COLD and doesn't move, only if I unplug the battery, wait a few minutes and put it back again, then it reads full MAX again.
This is driving me crazy
