Hi,
  I bought a 1991 318is with the knowledge it had a rod bearing making noise but that the head was rebuilt.  Cam trays , sprocket, new cam boxes ,old  lifters etc in trunk.   Car ran out nice but oil soaked #4 plug every time it sat overnight made it hard to crank and run until it burned off . I find oil leaking from the head gasket at the back passenger side of the head past the exhaust stud.  With the rod knocking on #4 I hoped a new head gasket might solve both issues ( oil leak and rod knocking)
   I did not lock the cam and crank . Foolishly reasoning that it runs fine now, there is resistance on all 3 and I have the keys and battery is unhooked.  Took apart, put together.  Torqued all to spec in the correct  sequence, put all together w a fresh oil change .   It fired right up but making lot of  valve noise,  doesnt want to idle but above 2000 sounds like she is running fine except the loud valvetrain.  I am by no means a expert but they sound dry.    Any ideas ?   Thanks
