Author Topic: Strange engine noise - timing chain?  (Read 7014 times)
alex230ro
Re: Strange engine noise - timing chain?
« Reply #15 on: September 03, 2020, 11:54:00 AM »
ok , this is the throttle body from the car is this normal ? This motivates me to  move to ITB :)
https://flic.kr/p/2jCXReW
anyway received the chain tensioner unfortunately it is extended i will try to compress it back to "transport postion"
« Last Edit: September 03, 2020, 11:56:28 AM by alex230ro »
« Reply #16 on: September 03, 2020, 03:03:21 PM »
No need to compress it, you want it to be extended before you start the engine. It is VERY bad to run the engine with it compressed, even if the "official" procedure says to do that. Basically, the chain will be loose and slap around a lot until it can cause the tensioner to pop open. It is much better to put it in extended so that the chain will remain tight at all times, even if it is more difficult to install like that.
alex230ro
« Reply #17 on: September 16, 2020, 03:20:22 AM »
Ok , did the test sound almost dissapeared still have some noise at start up, the E36 throttle does not have the play that E30 has, anyway i'm taking the car to a good friend that has a shop and i think he will get it right  :)
however i can't find this type of throttle body in the junkyards/ebay
https://www.realoem.com/bmw/enUS/showparts?id=AF91-EUR---E30-BMW-318is&diagId=13_0309
« Last Edit: September 16, 2020, 05:25:11 AM by alex230ro »
alex230ro
« Reply #18 on: September 17, 2020, 08:25:24 AM »
update, tested again with E36 throttle body  , sound does not come from throttle body :(
« Reply #19 on: September 17, 2020, 12:16:22 PM »
When you said "did the test sound almost dissapeared still have some noise at start up" what test did you do? If you meant that putting in the new chain tensioner caused the noise to be reduced, then it seems like the timing chain system has worn-out or damaged components. I know that you said that touching the throttle plate caused the noise to go away, so I'm a little confused. Honestly, after watching the videos again, I am not sure that I can tell which noise you are trying to eliminate.
alex230ro
« Reply #20 on: August 12, 2021, 05:50:40 AM »
One year later sound is still there, changed the timing chain tensioner but no luck. After further investigation appears that noise comes from the starter motor/gearbox area.
alex230ro
« Reply #21 on: October 25, 2021, 03:56:58 AM »
Aaaand yes , the noise comes from flywheel , the crown was loose appears that welding spots failed, will be welded again and since everything is taken apart also clutch will be changed . :)
alex230ro
« Reply #22 on: October 30, 2021, 03:43:51 AM »
Just to confirm, clutch changed and flywheel repaired all good. Much quieter.
« Reply #23 on: October 30, 2021, 12:35:23 PM »
Nice! I am glad to hear that you got it sorted out.
Warsteiner
  • -Receive: 21
« Reply #24 on: October 30, 2021, 03:19:32 PM »
Good Job!!
Now enjoy driving it!
Cheers,
~Ralph
