Author Topic: vacuum hose  (Read 3026 times)
M42Iberia
vacuum hose
« on: February 01, 2007, 06:43:50 PM »
Where does the vacuum hose that comes out of the fuel regulator plug into?
FL318is
vacuum hose
« Reply #1 on: February 01, 2007, 06:45:34 PM »
Not sure.  Can you point it out using http://www.realoem.com ?
M42Iberia
vacuum hose
« Reply #2 on: February 01, 2007, 06:52:34 PM »
never mind...i was successful with the search feature!!
mine has been dangling for months...good, another small fix that my car is almost certain to notice. i was reading bma tips section and they spoke of the fuel reg causing the pump to moan and cause efficiency issues. i'm almost certain that this is part of the culprit. i'll post with results later if anyone is interested.
FL318is
vacuum hose
« Reply #3 on: February 01, 2007, 06:53:57 PM »
Great.  Make sure to post the results.  You never know who is next.  BTW, Welcome to the group.
M42Iberia
vacuum hose
« Reply #4 on: February 01, 2007, 07:00:45 PM »
Quote from: FL318is;18648
http://realoem.com/bmw/showparts.do?model=AJ93&mospid=47318&btnr=13_0308&hg=13&fg=15
#11
....dang, i only have 10 posts
« Last Edit: February 01, 2007, 07:01:37 PM by M42Iberia »
Shocker
vacuum hose
« Reply #5 on: February 01, 2007, 07:08:55 PM »
Hooks up to the nipple on the bottom left side of the throttle body. (see pic)
Shocker
vacuum hose
« Reply #6 on: February 01, 2007, 07:10:42 PM »
Hooks up to the nipple on the bottom of the throttle body.  (see  pic)  The nipple isn’t in the picture but is on your Throttle body.
« Last Edit: April 15, 2007, 09:12:56 PM by Shocker »
16v of Fury
vacuum hose
« Reply #7 on: August 05, 2007, 09:17:52 PM »
I had to replace this hose --- I bought a generic piece of vacuum hose from Autozone but I definitely cut it a couple inches longer than it was from the factory.  Will this cause a problem?  I haven't tried to start it yet.
